Upgrade/Change From Ortofon MC-1 Turbo HOMC Cartridge - Suggestions?
0 Members and 1 Guest are viewing this topic. Read 1825 times.
tlarwa
I've been running an Ortofon MC-1 Turbo HOMC cartridge on my Thorens TD-280 Mk2 table with the TP28 arm for a while now. I've been happy with it, but as much because I don't have a ton to compare it to as anything else. I've just started my venture into tubes, and now have a Musical Paradise MP-301 Mk2 amp, a Parks Audio Budgie tube phono stage (with variable loading capabilities) and my DIY Frugel-Horn Mk3 speakers. As I'm now able to adjust loading, I'm considering trying a MM cartridge again (i.e. I understand the AT440Mla may sound better loaded somewhere other than 47k). Any advice or opinions on some good options that will mate well in my system? Budget is $200 or so (maybe $250ish) and I'm willing to buy used from a reputable seller to maximize my dollars and get into a better cartridge within that budget. I do not have a SUT, so a LOMC is probably not happening right now. I listen to classic rock, prog rock, progressive jazz, singer-songwriter stuff, etc. Pretty much anything but classical and country. I prefer a sound leaning towards dynamic and accurate, although the MC-1 Turbo has been reviewed as laid back and mellow, so I'm not sure how to compare that! In other words, I love the dynamic and accurate sound of Return to Forever, but also love listening to the vocals on an old Elton John album or Joni Mitchell on Court and Spark. I guess I need a versatile cartridge!
I appreciate any and all input.
Tom
neobop
  • BIRD LIVES
Hi,
Yes, the 440 responds well to loading. For those who find it too bright, you could go down to 30K or some increment between there and 47K.  All ATs like less than 200pF total. If you can do that (arm wire + cable + preamp), then you might not have to load it down, or so much.
Ortofon 2M Blue is popular in that price range. Depending on the sound you like, the Grado Gold is also popular. There's a Grado Sonata on Audiogon now, for $245. That's a $600 cart - you mentioned used.  To me, the AT sounds fastest - most detailed and the Grados are more "musical" and mellow.  The Ortofon is in between.
You might like the Denon DL-110, HOMC.  It works in heavier arms, I'm not sure about your TP28. I have an Ortofon M20FL Super for sale here. It responds amazingly well to loading. I also saw a SAE-1000 (HOMC) either here or Agon. These are all decent carts, not sure exactly what type sound you're after. Once you break in a 440 and have it tuned in, loaded etc, it's hard to beat for the money IMO.
neo
