Bryston BP-17 Preamp
0 Members and 1 Guest are viewing this topic. Read 34042 times.
rmurray
Re: Bryston BP-17 Preamp
« Reply #40 on: 26 Dec 2012, 12:37 am »
  There's that mysterious term "laid back". What does this mean. Seems to imply a less dynamic sound .  :scratch:
mkaiser
« Reply #41 on: 26 Dec 2012, 02:46 am »
I think it implies to being less upfront but still dynamic. In other words, the listener is feeling like they are a bit further back from the presentation getting all the music but, without having it thrown at them. My take anyway.
Mark
vegasdave
« Reply #42 on: 26 Dec 2012, 03:10 am »
Yeah, I would guess that's what James means.
rmurray
« Reply #43 on: 26 Dec 2012, 06:41 am »
  Thanks guys and a good listening in 2013 :thumb:
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #44 on: 26 Dec 2012, 12:29 pm »
Hi
What are those speakers?
james
Napalm
« Reply #45 on: 27 Dec 2012, 02:42 am »
Muffled treble.
spinner
« Reply #46 on: 27 Dec 2012, 12:52 pm »
  I was afraid that might be the case :lol:
« Reply #47 on: 27 Dec 2012, 01:13 pm »
Hi folks,
When I use the term laid-back I am not referring to tonal balance - that's the easy part :thumb:
I am referring to 'sound stage presentation'.  The BP-26 tends to start the sound-stage at the plane of the speakers or slightly behind and too the sides of the room - some instruments will be projected into the room whereas with the BP-17 the sound stage starts at the plane of the speakers and most instruments will be presented behind the plane of the speakers and to the left and right rear of the speakers.
So if you like the music projected into the room you may prefer the BP-26 but if you like the sound stage to move out and away from you then the BP-17 may be preferred.
Hope this helps.
james
« Last Edit: 27 Dec 2012, 03:11 pm by James Tanner »
Laundrew
« Reply #48 on: 27 Dec 2012, 02:12 pm »
I was cringing at the thought of someone saying it was "less musical" than the BP 26  :duh: :D
Whew
Be well...
redbook
  • the music is the blood...........
« Reply #49 on: 27 Dec 2012, 03:12 pm »
 I have heard this term applied to various power amps as well. I like the in our face up close presentation. Good there's something for everyone in this hobby but that's why the demo is important . :thumb:
werd
« Reply #50 on: 27 Dec 2012, 03:35 pm »
It's got 12db gain. The bp26 has around 23db gain. The overall system gain will be around 12db gain lower than the bp26. Low gain pre amps are typically quieter for noise especially with tubes.  To each their own but If you like more casual listening volumes I find 12 db pretty close to to perfect. My passive has a 12db or6 db gain switch. In 6 db it turns my 650 watt 14b into about 100 watt little purrer equivalent.
« Reply #51 on: 27 Dec 2012, 03:41 pm »
Werd - if your preamp is passive how does it have a gain switch?
james
werd
« Reply #52 on: 27 Dec 2012, 04:32 pm »
james
Ancient passive secret ...lol
I am guessing that the primary transformer winding can drive the gain switch.
mkaiser
« Reply #53 on: 27 Dec 2012, 05:43 pm »
Cool, so my comment was correct. I am getting better with this game as i get older.  :thumb:
Mark
bobNL
  • Some say he's a purist
« Reply #54 on: 30 Dec 2012, 08:35 pm »
Hi James,
If the BP17 is more laid back than the BP26, how would you compare / describe the sound of the bha-1 used as a preamp?
Bob
« Reply #55 on: 30 Dec 2012, 08:46 pm »
Hi James,
Bob
Hi
More like the 17.
James
remedy451
« Reply #56 on: 12 Feb 2013, 08:54 pm »
Yes
james
Hi James,
I'm leaning towards a BP-26 and understand that the Tape Loop can be used in a similar fashion to an HT Bypass.  Can you confirm this and if so how that would be configured as well as what implications there may be in setting up this way?
« Reply #57 on: 12 Feb 2013, 09:19 pm »
Hi James,
No the BP26 does not have a pass-through. Only the new BP17 preamp.
James
werd
« Reply #58 on: 25 Mar 2013, 04:10 pm »
i am curious on the back of the bp17 a ground connect is available. How is this typically used?
http://bryston.com/products/pre_amps/BP17.html
Why dont you sticky this thread?
budcook
« Reply #59 on: 25 Mar 2013, 05:37 pm »
Can someone tell me if the phono card for the BP-17 is the same as the one for the BP-26?  Also, is this card user replaceable?
