Bryston BP-17 Preamp
0 Members and 1 Guest are viewing this topic. Read 34084 times.
Laundrew
Re: Bryston BP-17 Preamp
« Reply #20 on: 16 Dec 2012, 04:33 pm »
My gothic adviser.
You are such a sweet talker werd  :D :thumb:
Be well...
werd
« Reply #21 on: 16 Dec 2012, 05:11 pm »
Be well...
Yah ok but let's just try and remain hurtful... :D
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #22 on: 16 Dec 2012, 05:32 pm »
Hi Folks
Like most things in life balanced lines have an up side and a downside.
Balanced lines solve a problem of noise pickup in the cables. Cables are antennas to the outside world and any RF or electromagnetic energy striking the cable can be amplifier in a 2 conductor RCA style cable by the system adding noise. Balance lines have 3 conductors and one of them is shunted to ground so any RF etc. hittiing the cable is cancelled due to a process called 'common mode noise reduction'. The longer the cable the more potential for pickup there is.
So in lengths longer than a meter I usually recommend using balanced lines. With shorter lengths it is not as critical.
Now the downside of Balanced lines - you need to have 2 more circuits in the signal path for a balanced line to work so it could be argued that those extra circuits can cause deterioration of the signal. Balanced lines can be done in a number of different ways - transformers or IC's or as we do it with 'Discrete Class A' circuits in order to minimize their contribution of complexity to the signal path.
Hope this helps.
james
spinner
« Reply #23 on: 16 Dec 2012, 05:47 pm »
  Yes thanks James. :thumb:
« Reply #24 on: 17 Dec 2012, 03:08 pm »
What's the gain on this pre?
From Engineering - 12dB
james
werd
« Reply #25 on: 17 Dec 2012, 04:54 pm »
james
No way!!  :thumb:. Whats the gain on the sp3 in two channel?
Phil
« Reply #26 on: 17 Dec 2012, 05:13 pm »
has the cost for the optional dac been determined?  how does the dac compare to your current digital equipment?
seems like a good match for my bdp-1.   :thumb:
« Reply #27 on: 17 Dec 2012, 09:26 pm »
Internal optional DAC is $1395 list but remember it is limited to 96/24.
james
KeithA
« Reply #28 on: 17 Dec 2012, 11:07 pm »
James,
Does the BP-17 have a HT Bypass?
Keith
« Reply #29 on: 17 Dec 2012, 11:09 pm »
James,
Keith
Yes
james
KeithA
« Reply #30 on: 17 Dec 2012, 11:10 pm »
werd
« Reply #31 on: 21 Dec 2012, 01:29 am »
Hi James
Does this pre amp mono ?
« Reply #32 on: 21 Dec 2012, 02:19 am »
Hi James
No sorry - no mono
james
KeithA
« Reply #33 on: 22 Dec 2012, 07:59 pm »
Yes
james
James
When I take a close look at the pics I can see a bypass indicator, but no button.
Does this mean that the bypass is only accessible via remote (which is an optional purchase item)?
Keith
« Reply #34 on: 22 Dec 2012, 08:42 pm »
James
Keith
Correct - it is a remote code.
james
vegasdave
« Reply #35 on: 23 Dec 2012, 10:31 am »
Looks good. Will there then be a replacement for the BP-26?
« Reply #36 on: 23 Dec 2012, 12:36 pm »
Hi
No replacement for the 26 planned.
james
vegasdave
« Reply #37 on: 24 Dec 2012, 04:49 am »
Hi
james
Would you say then James, that the BP-17 sounds better than the 26?
« Reply #38 on: 24 Dec 2012, 05:07 am »
No just a little different - more laid back.
james
vegasdave
« Reply #39 on: 24 Dec 2012, 09:57 pm »
james
Ok, sounds good.
