Intermittent bass
0 Members and 1 Guest are viewing this topic. Read 1265 times.
apoid1
Intermittent bass
« on: 7 Dec 2012, 03:06 pm »
Can anyone pose a reasonable solution for a long existing problem?
I have excellent audio equipment
Bryston B135 integrated amp & matching cd player,PSB Synchrony II speakers + audioquest comet biwire speaker cable & Rega P5 TT/dynavector.
The problem I'm having is I get a really deep satisfying bass on all sources then at any given point the bass becomes dull & undefined.
I've checked & even replaced many of the above items but the problem persists
No one has been able to point me in the right direction..
Has anyone experienced a similar problem or guess why bass weight is changing?
Mag
Re: Intermittent bass
« Reply #1 on: 8 Dec 2012, 12:43 am »
IMO, your speaker are 4 ohm speakers. So when you encounter demanding bass in recordings, also dependent on spl level. Your speakers are drawing as much as 7 volts, which results in lagging bass.
So what you need is a power conditioner that keeps the voltage level constant. With a constant voltage level your speakers will not lag and you will hear the difference for the better, instantly. :smoke:
apoid1
« Reply #2 on: 8 Dec 2012, 01:02 am »
Thank you
I currently use Audio Prism foundation II power conditioner?
Can you recommend one that is sutited to my needs?
apoid1
« Reply #3 on: 8 Dec 2012, 01:04 am »
I spoke with Audoquest,Bryston & PSB
Why is it that no one seems to have a clue how to help in this matter?
How come this matter has not come up before with others?
Mag
« Reply #4 on: 8 Dec 2012, 01:34 am »
I've wrote about it before. I have difficult to drive speakers, Paradigm Studio 100 v2.
Anyway, Werd a member on this board was over to listen to my system awhile back and recommended I buy his power conditioner. I was skeptical at the time, but he gave me a good deal, so I bought it. I noticed right away the difference in bass.
I'm using a Monster AVS 2000 or you can use a Bryston Bit or Torus conditioner. Also a power conditioner on the source removes RF noise, but a cheap one will do the job. :smoke:
apoid1
« Reply #5 on: 8 Dec 2012, 01:38 am »
Take a look at this $45 automatic voltage regulator on Amazon
http://www.amazon.com/APC-LE1200-Automatic-Voltage-Regulator/dp/B00009RA60/ref=cm_cr_pr_product_top
What do you think?
Mag
« Reply #6 on: 8 Dec 2012, 01:52 am »
Looks like junk to me. :nono:
apoid1
« Reply #7 on: 8 Dec 2012, 02:11 am »
There are quite a few supporting opinions
But I'm skeptical
werd
« Reply #8 on: 8 Dec 2012, 02:56 am »
Hi
Apoid1, it sounds like you are experiencing brown outs. Where do you live? Also what is on your hi if circuit? It also sounds like something in the vicinity is turning on (like a furnace or something) killing your power. You are losing power for some reason and it's most likely a power hungry device turning on while you are listening.
I am pretty sure that's it.
apoid1
« Reply #9 on: 8 Dec 2012, 03:19 am »
I believe you are right
Apartment in Staten Island,NY
I know the heat comes on this line as does air conditioner
in summer
« Last Edit: 8 Dec 2012, 06:16 am by apoid1 »
