Crossovers used
0 Members and 1 Guest are viewing this topic. Read 1798 times.
crushem
Crossovers used
« on: 6 Dec 2012, 03:29 pm »
Was wondering if the same crossover is used in the SST with the Hiquopon OW2 tweeter as the SongCenter with the LCY Ribbon tweeter ?
jsalk
Re: Crossovers used
« Reply #1 on: 7 Dec 2012, 01:39 pm »
No.  If you change any driver in a speaker, you basically have to design a new crossover to accommodate the new combination (unless the drivers are functionally identical).
- Jim
Art_Chicago
Re: Crossovers used
« Reply #2 on: 10 Dec 2012, 10:37 pm »
Jim,
Can one just swap the SEAS drivers in standard ST's with SEAS W15 that are used in the SCST's? wont' be cheap, but still?
Art
« Last Edit: 11 Dec 2012, 02:52 am by Art_Chicago »
jsalk
Re: Crossovers used
« Reply #3 on: 11 Dec 2012, 05:06 am »
Jim,
Art
No.  The crossover won't be right and the cabinet won't be right either.  It simply won't work.  Swapping the driver would result in a whole new speaker.
- Jim
