0 Members and 1 Guest are viewing this topic. Read 35740 times.
I am very sure that you are guiding me properly. I was using my Onkyo TX-8255 at Bass and treble controls turned up fully high.The volume turned down to less than 1/4 th it sounded good in its own limitations.Mids were not clear or even anywhere close to A70-t is. I could not listen to Onkyo longer either. Simply get bored when I listens to it. I had a Yamaha A1020 for few days as first replacement of Onkyo.Was not good with bass either nor with highs even on class A.I am just looking for opinions before heading in either way.I do not like the idea of playing with EQ settings for each and every track and do not know anything about it.I am leaning more towards sub as you mentioned before and gets the tube changed as the first step.Where I am unsure from your reply is the following.If the tube get old will it have a tendency to become less efficient with bass reproduction, if it get an unaltered signal at input. vs if I manipulate input signal to lower mid and high frquencies (What I did with digital EQ) will it still be weak in Bass reproduction.
Tried to call them seems like closed for the day.What do you think about these guyshttp://tctubes.com/tube-testing-service.aspx
