0 Members and 1 Guest are viewing this topic. Read 18215 times.
I can't comment on the differences, but FWIW, Bill Baker at Response Audio/Purity Audio has a SAS 11A for sale, which is very rare to see. People who have them love them and don't part with them and $1700 is an absolute steal.http://www.audionervosa.com/index.php?topic=4281.0
I have restarted my researched on pre-amps and I think I have narrowed my decision down to these 4:My current system consists of a Rotel Pre, Bryston 3BSST amp and custom speakers. I also have some basic room treatments installed. I am currently finding the vocal range a little harsh on my system and was hoping a tube pre might help soften them up a bit.Thanks for the advice
What about Bryston since your in CAN?
I've had the DeHavilland Mercury 3 and SAS 11A in my system. I bought the 11A. The only caution I would have is on the dual volume controls. If you think audiophilia nervosa is bad now, just wait until you start worrying whether you have the volume exactly equal in both the left and right channels.
Thanks for the advice thus far. I'll add a little more detail about my system. I use my computer as the source, feeding a Calyx DAC with external power supply into my preamp. I have always had the harshness (and I have changed everything except the Pre and Speakers) so I am actually fairly sure it is the speakers and not the preamp. To be clear I am not looking for a new preamp to fix the harshness, I am getting one because it is the last thing to upgrade on my list. If it works out that it helps with the harshness then that is great. Not the end of the world if it doesn't. That is what led me to the tube preamp. Haven't tried any tube equipment before so it is something I would to try out.Thanks again
The only one on your list that I have had ( and currently still have) is the Dodd. I have both the original battery pre and the most recent generation (but not variable)- all have the same open, detailed sound. The only thing that I can add is that both are very tuneable by changing tubes. Want color and musicality, use Mullards, want detail- Seimens, both- Amperex orange globe. I was talking to Gary Dodd a couple of weeks ago. On his newer pre, he was very high on a tube I wasn't familiar with- cheaper and better than the 6h30dr that many of us are using. Sorry, can't remember what it was. The point being, that the Dodd units respond very nicely to tube rolling. Scott
So you say that you are fairly sure your speakers are the cause of the harshness, but you want to try a new preamp to fix the harshness in your speakers??? Why not try a different pair of speakers or upgrade the crossover?
I use my computer as the source, feeding a Calyx DAC with external power supply into my preamp. again
