The goal of servo is to reduce the equivalent Qts value of the system by a factor of 3x for sealed and 8x for OB. Low Qts value has the same effect as high BL force factor value. The only way in real world we can implement something like that is with huge magnets. But then the effect of "stalk" (an effect that back EMF is so large that it reduces the output of the driver) becomes significant. So servo is really the best method to achieve excellent cone control (with low effective Qts) without suffering the stalk effect in the physical world.
This is the first I'm hearing of it. Who are his acolytes? Maybe his product is "hyped" because it is "the best"? Is that possible in your eyes? How are people including Danny supposed to respond when someone asks for a direct comparison?On which forums is mention of his product banned?Best regards,Steve.
NEVER again will I go back to big box colored bass.
Danny Stated - "Okay, Let me put it this way. I used a pair of SW-12-16FR servo controlled woofers in an open baffle speaker at RMAF as the lower drivers in a pair of speakers that I was demonstrating there. We measured them hitting 105db peaks in our listening room during the replay of a recording drum track. It was a high quality SPL meter that was sitting on my leg while I was seated in the listening area. They also played flat to 20Hz and were -3db down in the teens. And the stopping power and control of the servo system is quite evident even at lower volumes. Differences in resolution are not subtle regardless of volume."**********************************************************************************************************************************************************************Danny is being disingenuous here. A decent dipole sub can easily hit 105db somewhere in the bass. At high enough frequencies they will output more than a monopole. Mine (2 x AE IB12s) will theoretically do 113 db at 71Hz and 104 at 50Hz. However they will only do around 80db at 20Hz. So while his GR subs can probably hit 105db, and can also probably play flat to 20Hz, they can't do both at the same time.In spite of this being pointed out numerous times, he persists in fudging in the manner above. Frankly, his (and his acolytes) constant hyping of everything he makes and consequent slagging off of every other manufacturer is rather tiresome and why on some respected forums mention of his products is specifically (and uniquely) banned.It makes many people dismiss all of his products as nothing but hot air.I recommended his servo subs in the OP's other thread, but I did so grudgingly for the reasons above.
I really do wish that threads like these would not sink to the levels that some wish to drag them, especially by those that have no experience with the products that they deride. This is really beneath the quality of the vast majority of the discussions here on AC. Non-experiential discussion is called conjecture and should not be treated as gospel by anyone.
Yeah but Dave, this is the same false scent that others have been throwing out. You listen to a servo OB, then you say you won't go back to boxes. So what? What does that have to do with why servo is needed for a competent OB implementation? Apart from a condescending post by Brian referencing a 25-year old paper, there hasn't been a shred of technical data to support any of the claims being made.
it showed significant nonlinearity in speaker's suspension system and the box spring is 10 times more linear than that
I am also skeptical that servo's are needed for competent box-sub implementations either. For the guys that were curious, if you do your own forum searches elsewhere (or Amazon, etc, review sites), you will find plenty of people who have owned or heard Rythmik but felt that some other sub was just as good or better.Here's a home theater focused comparison that compares 4 different subs in room, including a Rythmik and a HSU. The reviewers felt that out of the four, these two tied for sound quality and accuracy. I spoke to these guys at length later on and they both confirmed it. So it goes to show you that non-servo subs should also be auditioned and/or considered when shopping.http://www.avsforum.com/t/1313176/shootout-epik-empire-vs-hsu-vtf-15h-vs-cht-cs18-1-vs-rythmik-fv15-vs-ed-a7s-450"Then there's the HSU. It tied with the Rythmik in sound quality over the other subs, and again these two had their own distinct sound so you might prefer one over the other."There is even video, sort of dramatically produced, and they show that the HSU starts and stops on a dime just as well without servo's"(the HSU) Just always sounded clean, tight, no distortion or anything. Again, just look at the intro video, like the Rythmik you can tell this thing is as accurate as they come."Again, that's just one example, but there's plenty of others like it. It wasn't a scientific AB test run by men in white coats, but it was real world, and unbiased. Anyway, Google is your friend.Back to OB's.
I detest accelerometer based subs.
Why don't you lift the game then, Dave. Post some facts instead of conjecture and marketing BS.
Are these OB or sealed?
Yes. Both.
Who makes an accelerometer-based OB servo sub?
I did. It sucked. Used an old Velodyne driver/amp setup with additional bass boost. Wouldn't play loud enough to continue on.
Well, that's very adventurous of you, Dave, but I hardly think it qualifies as a data point.
