0 Members and 1 Guest are viewing this topic. Read 111079 times.
Oh ok, I did not know that they are "your" products. I surely understand your point.So, let's not compare them to any other option, but just solve few issues I don't understand yet:- Many have said (also on this forum) that 2 GR's per side would be more than enough in dipole setup. On the other hand, it is also often said that due the acoustic realities, even 4 x 12" is not gonna give very strong bass in dipole and at least 15's or 18's should be used to get real punch on dynamic music. What's your comment on this? Can GR's really give so much more punch that you can use half less of them? If, why?- If I would use 4 GR's per side, the movement of drivers with normal listening levels should be quite minimal. And of course, that is a good thing from sound quality point of view. But doesn't this make servo functionality quite useless, compared to "normal" 1 driver subwoofer setup where driver moves a lot?
Danny, I have heard what you just said about RMAF, I just would like to understand the reasons for such performance? I mean; how come 2 of your drivers could give more output than 4 "normal" bass drivers in dipole setup? It is very hard to believe that 2 x 12" GR could match any setup with 4 x 15" or such.EDIT: and Danny, previous questions about DEQX experiences were directed to you, not Davey as I first wroted...
I think the DEQX is a silly gadget.....but not for the same reasons Danny does. The DEQX wouldn't be of interest to me because I think the concept of room "correction" via altering speaker system response is flawed.
Davey, I am totally with you on that aspect as well. Trying to correct for room related peaks and dips by altering the speakers output does not work.
Two have high moving mass that hinders acceleration
You've missed the point of the DEQX completely. If what the DEQX is doing is so bad, why are collaborating with HAL on doing the same thing?
It is not what it does that is bad. It is how it does it, and the quality of the parts and devices that are used in that unit that degrade the signal or interject noise. You have to look at the unit as a whole. It's all the overlooked little things like how in handles the A/C in the power supply etc. I would love to see a product with the functionality of the DEQX using the best parts and latest DAC processes. That is what HAL is working on.
The MMS of your SW12-16-FR is 104.9g. The Mms of the AE Dipole12 is 55g.
Based on my listening experiences, I don't agree with your continued dismissal of its quality. In fact, I don't think you've ever heard it used properly and are just speculating/badmouthing it in order to help you hype your supposed "best sounding but we've not even built it yet" product. That aside, can you be specific about the "how it does it" comment? What is it about "how it does it" that is "bad"?
Yeah, I have a tough time believing that a 12" woofer with an Fs of 25Hz is going to only have 55 grams of moving mass. That is close to the same weight as my 8" servo sub. Most 12" subs have a moving mass in the 180 to 250 gram range if the Fs is that low. Anyone independently measure the T/S parameters on those woofers?
Moving mass has nothing to do with acceleration.
Try this little trick. Measure a small woofer and note its frequency response. Now add a little mass to it with clay or something then measure it again. Guess what? It doesn't play as high. Why? Too much moving mass, and too slow.
Actually, when I perform a cross calculation using AE's published spec's for the Dipole-12 driver, the calculated Mms is 57.34 grams. So, pretty close. A smaller motor on those drivers so Mms that low doesn't seem unexpected.
