0 Members and 1 Guest are viewing this topic. Read 6872 times.
With the green thinking these days why would not all manfs be o[n] the wagon ?
The sonic benefits of battery AC power is a dead silent noise floor when properly done.
Dave,The laptop fire was a Lithium Polymer battery with high output impedance. Those have to be charged in a fire protective bag in a home environment.The LiFePO4 chemistry is used in automobile applications as it does not catch on fire. They do not need protective bags for recharging. These are very low impedance devices like AGM batteries.I have been using the A123 chemistry LiFePO4 batteries for a few years with audio gear. Their lifetime is between 10-15 years from what I have seen. Think that works for most product lifetimes.To destroy a LiFePO4 battery, you put it in a bucket of salt water for a few days. Passivated and ready for the land fill. Less hazmat than AGM's.
A battery is kind of like a funny capacitor. Power goes in, waits, and comes out.
I stand corrected on the LiFePO4 issue. I get that part. I was speaking too generally there. My bad. The potential for disaster that I was thinking (or not - way too many thoughts at that moment) about is the battery balance issues in charging and cells dying, money flying, etc, etc... Battery management for many people is a PITA and I be one o dem guys. That is why I am an AGM proponent for most applications.Dave
Mike, they're Exide 500Ah, 2V ex telco batteries. I think it's probably a case of survival of the fittest, in that these batteries were still passing their performance tests for the telco at twenty years when others of the same age had died. As a home power supply they are never discharged below 24V [12 X2] and even that low is quite rare. I guess it's not fair to claim these as a standard for performance in that they could well be the last of their breed still going.Rollo, I don't know what the battery BUSS does but as I understand it, a battery bank, being a very big capacitor is also a low pass filter so it needs smaller caps in parallel with it to pass the higher frequencies if you're using the battery power supply direct to your equipment [and excluding the caps in a normal in-built power supply]. If you use an inverter to change your battery DC to the same voltage AC as your grid supply, the caps in any standard grid type piece of equipment should do the job. jules
A 12VDC, 100Ah AGM battery is the equivalent to a 30000 Farad capacitor
