TT bearing assembly diagram?
0 Members and 1 Guest are viewing this topic. Read 2299 times.
Minn Mark
« on: 8 Nov 2012, 01:40 pm »
Sorry for the ignorance, but can someone upload a nice diagram of a TT bearing assembly (I know there are different styles) with the various parts labeled?  I think I get most of the design, but (sorry) I don 't know what a 'thrust plate' is. A simple diagram would be great help. Thanks in advance.
Minn Mark
Ericus Rex
Re: TT bearing assembly diagram?
« Reply #1 on: 8 Nov 2012, 05:15 pm »
Don't know of a diagram but the Thrust Plate in the flat plate at the bottom of the bearing that the spindle point spins on.  TT bearings are usually very simple: Housing, thrust plate, spindle.  Sometimes the spindle's point is some new fangled space age material.  Sometimes instead of a thrust plate you find a single ball bearing in the center of the hole.  Sometimes the bearing is inverted but the components are usually similar.
simoon
« Reply #2 on: 8 Nov 2012, 05:57 pm »
Here's a guy that built a DIY TT. Probably doesn't sound very good, but his solution for the bearing is quite ingenious. Check out the photos of his bearing about 1/3 of the way down the page. It will give you an idea of a basic bearing.
http://www.altmann.haan.de/turntable/
diyhifisupply sells inverted bearings. There are some photos here -
http://www.diyhifisupply.com/bearing
Ericus Rex
« Reply #3 on: 9 Nov 2012, 01:07 am »
Brilliant!  Using an engine valve as a spindle.  Genius!  Also genius is using your computer to control the speed of the stepper motor.  That guy has some wits.
Minn Mark
« Reply #4 on: 9 Nov 2012, 05:38 pm »
Thank you. The pictures and links help a lot.
Mark
