Nightshade Audio NS60 SE Amp OSU vs Michigan Pricing!! Great Deal til kickoff!
0 Members and 1 Guest are viewing this topic. Read 2478 times.
rklein
  • My finest audio piece ever!!
I am putting my Nightshade Audio gear up for sale.  It would be preferred if this gear was purchased a whole.  However, I will absolutely consider splitting them up(although it would be a shame…).
It looks like I may have a prospective buyer for the Beacon III preamp as well as the 240 watt filament Power Supply.  Therefore, in honor of "The Big Game", I will sell my NS-60 SE tube amp for $1,250!!  This is a great price for a piece of gear that would cost over $2,600 to replicate!  This price include all tubes necessary for operation and shipping.  This price is good until kickoff of the OSU vs Michigan game this Saturday.   GO BUCKS!!!
Listed below are the specs on the NS-60 SE tube amp along with the Beacon III tubed preamp.   All options and upgrades were selected to provide the most sonic improvement. Each upgrade builds upon the strengths of the other.  This is wonderful sounding gear in absolute mint condition but I have decided to go in another direction…hence the sale.
Also listed is an optional 240 watt Power Supply that I ordered from Blair at Nightshade.  Keep in mind that both the amp and preamp already come with separate smaller filament Power Supplies.  However, the beefier 240 watt Power Supply is a nice step up.  It can be used with either piece or can be used to power both of them at the same time(how I used it).
Both the NS-60SE & Beacon III are designed to be compatible with a wide range of equipment. As you can see from the pictures this gear is some of the finest looking stuff that Blair has ever built. (just check his avatar on AC…it is my NS-60 SE)
Based on current pricing NS-60 SE with the below options would run $2,580.  The Beacon III with the below options would run $1,450.  The 240 watt Power Supply would run $290.
I have  a matched quad of Gold Lion KT88's, a matched quad of Winged C 6L6's as well as a set of Tung-Sol 6SN7GTB's along with RCA 6SN7's that I can supply as well.
Buyer pays shipping.  Check, Money Order or PayPal (add 3%)
Thanks for looking,
Randy
NS-60 SE Tube Amplifier      Asking $1,500
•   Power: 60 watts per channel full bandwidth with KT88 or 6550 tubes
•   Frequency Response: 20-20,000hz
•   Usable Tubes: KT88, 6550, 6L6 or EL34 x 4, 6SN7 x 3, 5U4 or 5AR4 x 2
•   Dynaco 60 watt iron
•   Super Edition (SE) Upgrade
•   1940's mod upgraded to dual parallel rectification
•   Switchable tube or solid state rectification
•   DC Filaments
•   IEC Power Socket
•   Variable Negative Feedback
•   Tunable Bias (control on front)
•   Low noise power supply
•   Industrial quality capacitors
•   Upgraded wood package consisting of solid wood quilted maple wrap
•   Chassis color – Crimson Red
Beacon III Tube Preamp      Asking $850
•   HT bypass
•   True Buffer mode
•   Solid state rectifier
•   Two inputs
•   IEC power socket
•   Link capacitor output coupling
•   DC filaments, (external high current power supply)
•   Upgraded wood package consisting of solid wood quilted maple sides
240 Watt Filament DC Power Supply (with speakon cables)   Asking $200
•   Chassis Color – Crimson Red
•   Can be used to power filaments in both the NS60 SE and Beacon III simultaneously or separately
« Last Edit: 23 Nov 2012, 04:56 pm by rklein »
rklein
NS-60 SE Tube Amp for $1,400 and I will include all necessary tubes for operation.
Beacon  III Tube Preamp for $800 and I will include 3 6SN7 tubes.
240 watt filament Power Supply for either/or NS-60 SE and Beacon III $190
Will accept $2,100 if all three pieces purchased together.
Randy
rklein
I have gotten a couple of PM's asking about the 240 watt Power Supply and do you need a 240 watt wall outlet...
The answer is the 240 watt Filament Power Supply has nothing to do with the wall outlet voltage.  The NS-60 SE can be plugged right into the standard 110 volt wall outlet with a regular Power Cord of your choosing, attaching to the IEC on the back of the amp. When I am talking about the 240 watt filament Power Supply, I am referring to the filament option that Blair at Nightshade Audio builds into his amps and preamps. Those filaments need to be powered. If you look at the back of the amp you will notice a hole next to the IEC. That is where the filament power supply plug goes.
The NS-60 SE and the Beacon III Preamp have separate external filament power supplies(with cord/plug) that comes standard with the amp & preamp.  However, the 240 watt filament power supply that I am selling separately is a "step up" over the stock filament power supply.
I should also mention that whether you just use the stock external filament Power Supply or get the 240 watt filament power supply, these power supplies are also plugged into an AC outlet as well via a regular power cord.
Hope that clears this question up.
Randy
rklein
Price Reduction
NS-60 SE Tube Amp for $1,350 and I will include all necessary tubes for operation.
(a matched quad of Gold Lion KT-88's, three 6SN7's, two 5AR-4's valued at $300)
Beacon  III Tube Preamp for $750 and I will include 3 6SN7 tubes.
(three virtually new Tung-Sol 6SN7GTB's valued at $60)
240 watt filament Power Supply for either/or NS-60 SE and Beacon III $180
Will accept $2,050 if all three pieces purchased together.
Randy
rklein
In addition to the reduced price above, I will provide shipping at no cost to the buyer.  I will also accept PP with no fee to the buyer.
AND if all three pieces go to the same buyer the price will be $2,000.
For those into tube gear, this is a great system.  For those thinking about tubes this system gets you into the game with quality gear at a reasonable price tag.  Especially, with me providing all the tubes at no cost.
Randy
rklein
In honor of the "BIG GAME" - OSU vs The School up North, I am reducing my price for these pieces to $1,900 shipped.  This price includes all tubes necessary for operation.  This price is good up until kick off.
GO BUCKS!!
rklein
It looks like I may have a prospective buyer for the Beacon III preamp as well as the 240 watt filament Power Supply.  Therefore, in honor of "The Big Game", I will sell my NS-60 SE tube amp for $1,250!!  This is a great price for a piece of gear that would cost over $2,600 to replicate!  This price include all tubes necessary for operation (worth another $300-$400!) and shipping.  This price is good until kickoff of the OSU vs Michigan game this Saturday.   GO BUCKS!!!
Enjoy your Thanksgiving
Randy
« Last Edit: 23 Nov 2012, 04:57 pm by rklein »
