opening 4b st for cleaning
0 Members and 1 Guest are viewing this topic. Read 2382 times.
ancient hippy
« on: 4 Nov 2012, 08:03 pm »
 tried to open my amp for cleaning the heads of the screws are round. does the 4b st not use robertson screws
joey116
Re: opening 4b st for cleaning
« Reply #1 on: 4 Nov 2012, 08:12 pm »
I always thought so, however, just checked my 4B and 6B, they are all torx head screws.
http://en.wikipedia.org/wiki/Torx
ancient hippy
« Reply #2 on: 4 Nov 2012, 08:19 pm »
i dont know what a torx head screw is guess ill google it. my nrb uses robertsons
joey116
« Reply #3 on: 4 Nov 2012, 08:23 pm »
Check the wiki link in my previous message. The drivers are readily available, just don't try to use an allen key, they are not the same.
ancient hippy
« Reply #4 on: 4 Nov 2012, 08:38 pm »
your right. my neighbor lent me the proper tools. when i first looked i thought the heads were stripped.thanks so much
brucek
« Reply #5 on: 4 Nov 2012, 08:50 pm »
So, was the cleaning actually required after you opened it?
brucek
ancient hippy
« Reply #6 on: 4 Nov 2012, 09:02 pm »
yes actually just dust. is it okay to use electrical contact cleaner?
brucek
« Reply #7 on: 4 Nov 2012, 09:19 pm »
I wouldn't use contact cleaner. It may wash away thermal compound that's used on some transistors.
Bryston amplifiers don't use fans, and as such won't accumulated enough dust over their lifetime to matter.
If you feel compelled, just blow it out with some compressed air in a can.
brucek
Fernando
  • fernando _at_ -34.899705, -56.158880
« Reply #8 on: 4 Nov 2012, 11:09 pm »
It surprised me that my new 4B SST2 has Torx instead of Robertson.
I like the Robertson much more than the Torx, I'd change them just because ... - and yes, my old 4B ST has Robertson. It needs to be cleaned too, so this thread came out just in time  :)
ancient hippy
« Reply #9 on: 4 Nov 2012, 11:12 pm »
it seems unpatriotic not use robertson
joey116
« Reply #10 on: 4 Nov 2012, 11:36 pm »
I imagine the decision to stop using robertson screws is because of the problem getting drivers outside of Canada, I saw an ad. on Ebay a few years ago for a "special Bryston screwdriver"  just a plain old green robbie.
