DIY Cheap DAC with Volume control
0 Members and 1 Guest are viewing this topic. Read 8857 times.
this_is_vv
« on: 4 Nov 2012, 06:01 am »
I have a PC which runs linux mpd and streams the entire music from my NAS server ... the connection i tried was
PC->DAC-> Active Xover->AMp->speakers
my only problem is there is no Volume control in this path and the software volume control is not upto the mark i am looking for a DAC the can also be like volume attuenator without loosing the quality...any things you guys can suggest???
Also would having a DAC with volume control will help with the current setup i have...?
V
Letitroll98
  • Too loud is just right
Re: DIY Cheap DAC with Volume control
« Reply #1 on: 4 Nov 2012, 06:15 am »
One product that I like a lot is the Audio GD 12.1 http://www.audio-gd.com/Pro/Headphoneamp/NFB12/NFB12EN.htm
Dual Wolfson WM8741 chips, Non-feedback design, ALPS 27 volume pot, switchable digital filters, variable gain settings, and a decent headphone amp to boot.  All for $215.00 plus shipping.
this_is_vv
« Reply #2 on: 4 Nov 2012, 06:49 am »
is the volume for headphone or for RCA???
again DAC outputs are going to active crossover to amps...will this work?
V
Letitroll98
« Reply #3 on: 4 Nov 2012, 05:05 pm »
Yes, it absolutely works with all outputs.  You can open the case and configure it not to, but the default from the factory is the volume controls all outputs, with the only caveat being you do have to set the front panel switch to variable.  Additionally there is a high/low gain setting that does a nice job of matching the output to your amps.
Posting after happy hour at my house, which is anytime after noon, I did neglect to see you specified DIY, but for the price I hardly see the need.  You can alternately go up in price at Audio GD to the NFB-5.32 at $378 which gets you 32bit / 384K Asynchronous Transfer USB inputs and better parts selection.  He also has a similar line using the Sabre ES9018 chip.
For DIY there is the Hifimediy Sabre DAC. ES9023 http://hifimediy.com/index.php?route=product/product&path=62&product_id=85 for $68 that says it has an input that goes thru a volume pot.  Pretty new product so I don't know how it might sound.  Here's the AC thread linking to it.  http://www.audiocircle.com/index.php?topic=110299.0
Steidl Guitars
« Reply #4 on: 4 Nov 2012, 08:23 pm »
Another that I think fits the bill is the Audioengine D1:
http://audioengineusa.com/Store/Audioengine-D1
persisting1
this_is_vv
« Reply #6 on: 5 Nov 2012, 04:28 am »
Not sure how much you want to spend.
Maverick Audio has two DACs that fit the bill.
D1
http://www.mav-audio.com/base/product/tube_magic_d1
D2
http://www.mav-audio.com/base/product/tubemagic_d2
Have you thought of a passive preamp?
http://app.audiogon.com/listings/solid-state-ciaudio-vpc-1-passive-volume-control-2012-11-04-preamplifiers-75035
i want to be around 300$ max ....but passive volume control is a good idea...i already have an ODAC which i am kinda being very lazy not using it but with this passive volume control i think thats a good deal...
again stupid question this will be able to put volume control  after DAC so connection would be
PC->DAC-> Passive volume control -> Active crossover -> amp->speaker
V
jmc207
« Reply #7 on: 5 Nov 2012, 06:08 am »
Yes, I think your component order is correct. As for relatively inexpensive Passives, here are a few good ones:
http://luminousaudio.com/axiom.html
http://www.tubeaudiostore.com/basicpotinbox.html
http://richardleeaudio.com/
persisting1
« Reply #8 on: 5 Nov 2012, 06:21 am »
From what I've read, you might be happy with the Audiengine D1. I'm sure you'll find a buyer for your ODAC. Heck, I've been eying it myself  :o
this_is_vv
« Reply #9 on: 5 Nov 2012, 08:30 am »
you want one?
http://www.audiocircle.com/index.php?topic=109356.0
V
persisting1
« Reply #10 on: 5 Nov 2012, 08:46 am »
I've been thinking about it. Wish it was the RCA version.
JohnR
« Reply #11 on: 5 Nov 2012, 09:00 am »
Why don't you just make one? It's easy enough. What crossover are you using BTW?
this_is_vv
« Reply #12 on: 5 Nov 2012, 02:59 pm »
Behringer DCX 2496
V
this_is_vv
« Reply #13 on: 5 Nov 2012, 04:15 pm »
john
i am using Behringer DCX 2496
V
« Reply #14 on: 5 Nov 2012, 06:27 pm »
Scott Endler mods the DAC section of the Behringer for under $300:
http://mysite.verizon.net/vze4c5pt/
He did my DEQ2496.  I also bought stepped attenuators from him (use at power amp inputs for best results, like any passive) and all my signal cabling.  Good guy, good work, great prices.
Yes, quality volume controls make a sonic difference.  (cheap + volume control = poor way to save money)
randytsuch
« Reply #15 on: 5 Nov 2012, 07:46 pm »
If it was me, I would not add a DAC in front of the Behringer.
If you feed the Behringer an analog signal, then it has to convert to digital, do it's processing, then reconvert to analog.
So, you would be doing this :  D->A->D->A
I think there are a few people that offer atteneution solutions for what you want to do, but they are not cheap because you have to deal with more channels.
Randy
this_is_vv
« Reply #16 on: 5 Nov 2012, 09:23 pm »
Randy
So how do you suggest i go with my current setup...Behringer  doesnt have the USB input....so how do i make it work???
V
randytsuch
« Reply #17 on: 6 Nov 2012, 02:08 am »
How about USB to SPDIF?
So you have
PC -> USB -> SPDIF -> Behringer (SPDIF -> Analog)
this_is_vv
« Reply #18 on: 6 Nov 2012, 02:33 am »
So you have
never tried that route so have no idea about it.....does DCX2496 comes with SPDIF i dont have on one i have...or is it a mod too
charmerci
