0 Members and 1 Guest are viewing this topic. Read 5830 times.
Was interested in trying the 12SN7. Looks like they are about 1/2 the price of similar 6SN7 tubes on Ebay, but spec-wise they look pretty indentical to the 6SN7, except for needing 12.6V...Any thoughts on the 12SN7?
Maybe I need to shop around some more. I don't have anything against the 6SN7, and there certainly are more choices in the 6 vs the 12SN7. Do you believe in the virtue of having a seperate transformer for the heaters?
Hi strider...Been looking at the same preamp, so interested in your project. Does the LDO voltage regulator for the heaters require a CT transformer? Also, can you post which transformers you bought for the project?The reason I ask is that his LV Regulator kit can take a CT or non-CT transformer, and he recommends using a CT tranny.Odd that his website mentions only one transformer, not two Mike
strider, there is an all-in-one manual, I have it. But, it sucks just as much as the separate manuals, I ended up reading the manuals for everything related to power supplies and aikidos I could, including the 9-pin manual which is a bit better.I think I have it figured out, my Aikido sounds amazing, so feel free to ask me any questions, I def. needed some help along the way...
Could you elaborate on the how you implemented the relay for turning the heater power supply on early?
Sorry, I actually did not do this, but was considering it.... All you'd need is a 30 sec. delay relay and the power switch would immediately turn on the heaters and the relay would delay the power going to the HV trafo for that 30 seconds.
Yup, but you could look for a SPST (single pole single throw) but the DPDT will work fine too,
