Setting up my Aikido Octal All in One to use 12v tubes...
0 Members and 1 Guest are viewing this topic. Read 5828 times.
strider
Re: Setting up my Aikido Octal All in One to use 12v tubes...
« Reply #20 on: 3 Nov 2012, 02:32 pm »
1 Mississippi, 2 Mississippi....20 Mississippi
http://tubedepot.com/p-dpst-3way.html
This will help with the wiring.
That's similar in function to the switch that I am currently using, which I got from the glassware store also.
http://glass-ware.stores.yahoo.net/acswitch.html
strider
« Reply #21 on: 3 Nov 2012, 02:41 pm »
Digging through my parts bins last night I found a 12V/5A toroidal transformer, so I think I may go ahead and use it with the current full wave bridge rectification. The transformer is single primary and secondary, any reason why it wouldn't be a good idea to try?
Ben
strider
« Reply #22 on: 11 Nov 2012, 02:40 pm »
So instead of using the toroidal transformer I ordered a Hammond transformer from Mouser, a 166L12. Mouser shows it as 12.6v/2.5a which is perfect for the heater supply. When I receive the transformer I look at the data sheet that came with it and it is center tapped.
From my understanding of a center tapped transformer the center tap is taken from the middle of the secondary winding. In this particular example, there would be 6.3v from the one secondary tap to the center and 6.3v from the other secondary tap to the center tap. Could I ignore the center tap and use just the two scondary taps and get the 12.6v that I need?
Speedskater
  • Kevin
« Reply #23 on: 11 Nov 2012, 03:01 pm »
Sure, you don't need to connect the center tap on a 3 terminal winding.
Some secondaries are two separate windings (4 taps) and you need to jumper the correct taps.
