LAST BUMP: Legacy (Coda) 4 Channel Class A/AB amp - $649 OBO
0 Members and 1 Guest are viewing this topic. Read 6559 times.
jackman
Excellent condition, very versitile Legacy amplifier made by Coda.  This amp can be used in 2, 3, 4 channel configuration.
The amp is compact and very good looking/sounding.  Built like a tank and runs cool -  first 30watts Class A.  400 watts per channel in 2 channel mode.  It is also exceptionally quiet and functions perfectly.
Coda is famous for making amps for Legacy Audio and Innersound.
Securely packed in original box with original packaging and manual.
Information from Coda:
* True state-of-the-art multichannel performance in a high quality, hand crafted chassis
* 100 Watts into 8 Ohms x 4 in four channel mode
* 100 Watts into 8 Ohms x 2 and 400 Watts into 8 Ohms x 1 in three channel mode
* 400 Watts into 8 Ohms x 2 in two channel mode
* Precision Bias Class A/AB, pure Class A at typical listening levels
* Fully discrete FET differential input stage DC coupled to an ultra wideband bipolar output stage
* Very high linear damping with no overall feedback
* 1.4 kVA (2.8 kVA peak) toroidal power transformer
* Low impedance power supply filter capacitor array
* SMOBC (solder mask over bare copper) FR-4 glass epoxy printed circuit boards
* Designed, manufactured and assembled in the USA
This amp originally sold for around $3,000
PRICE REDUCED:  $649, plus shipping and PayPal from 60564.  I'll also deliver if you are local and will be happy to offer an audition.
Jack
« Last Edit: 2 Nov 2012, 04:52 pm by jackman »
richidoo
Re: Legacy (Coda) 4 Channel Class A/AB amp: $749 OBO
« Reply #1 on: 26 Oct 2012, 03:33 pm »
And grew out of the original Threshold company with Nelson Pass
http://www.6moons.com/audioreviews/coda/unison.html
jackman
PRICE REDUCED: Legacy (Coda) 4 Channel Class A/AB amp - $699
« Reply #2 on: 26 Oct 2012, 05:37 pm »
Thanks for the info, I knew there was a connection with Nelson Pass.  For an amp that runs partially in Class A, it is very cool and has excellent heat sinks.  The case is all steel with an anodized aluminum front panel, and the heat sinks are steel.  It looks very similar to the one in the link Richidoo attached.
This amp is very well made and sounds very good.  Compared to the Ncore, it is a bit warmer sounding with more emphasis on the midrange.  Bass is powerful and the high end is detailed and airy without being overly bright.  It all depends on the speakers but the amp sounds very good in my system.  Anyone in the Chicago area is welcome to check it out.
I've spoken with the guys at Coda, in California, and they are very cool.  The amp has never received or needed service and is in perfect (9/10)shape.  The internals are very well laid out and it is exceptionally powerful in bridged mode.  The bridge mode is activated by a switch on the rear panel.  I purchased the amp NOS from a private seller and have used it for years without issue.  Also, I'm negotiable on price if anyone wants to shoot me an offer.
Jack
Priced Reduced to $  $649 plus shipping.
« Last Edit: 2 Nov 2012, 04:59 pm by jackman »
mboxler
Re: REDUCED: Legacy (Coda) 4 Channel Class A/AB amp - $699
« Reply #3 on: 26 Oct 2012, 10:31 pm »
Hi Jack...
Any idea if these could drive a pair of 4 ohm subwoofers???
Mike
jackman
« Reply #4 on: 26 Oct 2012, 10:58 pm »
I've never tried it on a 4 ohm subwoofer but it worked well on my 4ohm speakers.  The owners manual states it is rated at 4 X 225 WPC into a 4ohm load.  In bridged mode, I believe it's around 2 X 400 WPC.   My subs are rated at 8ohm and the amp worked well, especially in two channel bridged mode.
jackman
Last reduction and bump before Paypal.  This is a really good sounding amp, built like a tank and very versatile. In three channel mode, it can run your front three channels or two mains and a sub.  Very smooth sounding, cool running and whisper quiet.  In two channel mode it is very powerful. I mainly used it in four channel mode.
I've got too much gear and was hoping someone on AC would want this before going to Audiogon.  Thanks.
Reduced!  $649 plus shipping from 60564
