BDA-1 integer mode
0 Members and 1 Guest are viewing this topic. Read 4017 times.
bluemark81
BDA-1 integer mode
« on: 23 Oct 2012, 02:38 am »
Does anyone know if the BDA-1 can support integer mode?
Phil A
Re: BDA-1 integer mode
« Reply #1 on: 23 Oct 2012, 02:49 am »
Don't know but here's a way to tell - http://bitperfectsound.blogspot.com/p/manual.html
bluemark81
« Reply #2 on: 23 Oct 2012, 11:14 am »
I tried that and according to it, the answer is no.  I was hoping I was doing something wrong in checking it.  That is unfortunate and a bit surprising as I like the BDA-1.  I wonder if it is something that can be added through a software update.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #3 on: 24 Oct 2012, 01:17 am »
Hi Folks
I tried Bit Perfect App with the new BDA-2 and Integer Mode says Yes  :thumb:
James
« Reply #4 on: 24 Oct 2012, 01:20 am »
So I guess the question becomes - does Bit Perfect compete with the other music players like Amarra and Audirvana and Pure Music ?
James
bluemark81
« Reply #5 on: 24 Oct 2012, 01:24 am »
Hi Folks
James
James:
Is there a possible firmware upgrade for the BDA-1 to handle integer mode?  I only bought the BDA-1 about 6 months ago.  I don't want to have to trade it in already.
« Reply #6 on: 24 Oct 2012, 01:42 am »
James:
Sorry I do not think so as the chips in the BDA-2 are totally different. I have not tried the BDA-1 with Bit Perfect yet as this program is new to me but I will.  I am using the new USB asynchronous input on the BDA-2 so I assume that is why the BDA-2 can deal with the Integer playback.
I had to open the Bit Perfect Preferences window and close it again while playing a file before it showed YES.
James
bluemark81
« Reply #7 on: 24 Oct 2012, 01:50 am »
James
Yes, that is what I did as well, but unfortunately, mine says NO.  Want to buy a very slightly used BDA-1?   :lol:
Let me know what you find out anyway when you test it.  I'm expecting it to give the same results, but hopefully, I've done something wrong.
« Reply #8 on: 24 Oct 2012, 01:51 am »
Are you using the USB input or Optical?
James
bluemark81
« Reply #9 on: 24 Oct 2012, 01:53 am »
James
I first tried it with optical and now I'm using a hiFace usb/spdif interface as I have some hi rez files (>92 kHz).
« Reply #10 on: 24 Oct 2012, 01:55 am »
Ok I will try it at work tomorrow - I can play 192/24 USB so far with no glitches on the 2.
We are planing on introducing an outboard USB interface that is identical to the one in the 2 to go with the BDA-1 so that might solve the issue for you.
James
bluemark81
« Reply #11 on: 24 Oct 2012, 02:09 am »
James
I would be very interested.  I suspect you could test it out first to see if it does the trick?  Would the interface allow higher rez files over usb?
« Reply #12 on: 24 Oct 2012, 02:15 am »
Yes it should work identically to the USB in the BDA-2.  I will certainly let you know when we get the prototype together.
James
bluemark81
« Reply #13 on: 24 Oct 2012, 02:22 am »
James
Great.  I may be putting too much emphasis on this "integer mode", but most say it makes a marked improvement.  What do you anticipate the expected release date to be?
« Reply #14 on: 24 Oct 2012, 02:30 am »
I would say about 3 months.
James
Marius
« Reply #15 on: 24 Oct 2012, 07:51 am »
Hi James,
Ive bought the Bitperfect app, but in fact never use it. Ever since I installed it my Macbook started to behave unexpectedly.... Up to the point where closing it or an interfering app, made it play my mail-sent sounds.... strange, and made me feel things were sent I didn't know of...
Other than that, I could not hear any difference on the Mac between with or without. That might be a completely different story when using the sound out into an extermal Dac of course, but as said, haven't tried that yet.
Would have been very nice, such a small app, making great systemic sonic improvements.
I stick with Audirvana + for now.
Very keen to hear your test results though.
Marius
James
« Reply #16 on: 24 Oct 2012, 10:50 am »
Hi James,
Marius
Hi Marius
Yes I made the mistake of leaving Bit Perfect engaged and switched to Amarra and got sound through the DAC as well as through the laptop computer.
Also I have ordered a new laptop as my MAC only has 2GB of memory and most of these add ons want 4GB minimum - especially when playing hi-res files.
James
bluemark81
« Reply #17 on: 24 Oct 2012, 11:39 am »
No issues of that sort with me yet.  I'm only using bit perfect for now, on a mac mini with 8 gig running snow leopard.
« Reply #18 on: 24 Oct 2012, 11:50 am »
Hi
So given your research and listening does Bit Perfect appear to do all that the much more expensive programs do?  Also do you hear a difference between Bit Perfect engaged vs standard iTunes?
james
bluemark81
« Reply #19 on: 24 Oct 2012, 12:39 pm »
Hi
james
James:
To be fair, I really only got things up and running last evening and hadn't had much of a chance to experiment.  Currently, I am listening to things through headphones and a headphone amp as we are in the midst of renos and all my gear is stored away until we are done.  I will try turning BP off tonight to see what effect it has.
Tell me this, what are you using to connect your mac to the BDA-2 when you tested it?  On another forum where I was inquiring about integer mode with the BDA-1, this is the response I got:
All the reviews of the Bryston DAC say its USB input is inferior to its S/PDIF input. Therefore, you probably should try a high quality Toslink cable from the Mini to the Bryston instead of using USB. (To use Toslink, set the sound output device to Internal.)
Since integer mode is impossible with S/PDIF, that would moot your question.
I am using SPDIF on the BDA-1 by converting the USB out on my mini to SPDIF using a HiFace1 interface.
