0 Members and 1 Guest are viewing this topic. Read 5932 times.
HEllo everyone, I am wondering if my tubes that caused the scratchy noise have gone bad?
wow, thank you so much guys for the input! I really appreciate it. I will try to keep the different tubes in for a week as I only had the tubes in for about 5 hours instead of full time like the other tubes, that the scratchy noise came from when i would turn the volume knob. Again i thank you all for the comments and really am thankful as I am new to tubes heh. I just know which tubes to get for my amp and how to put them in lolhave a great evening.
Hi 79,If changing the tubes relieves the scratchy problem, then most likely the tubes in question has negative grid current problems, probably a gas problem, and/or some cathode material has deposited on the grid itself.Cheers.
The reason you are hearing less scratchiness with the 12AU7 than with the 12AT7 is the difference in gain between the tubes. The 12AT7 has a gain factor of 60 and the 12AU7 with a gain factor if 40. Jim
Your welcome Jim. If you have a voltmeter handy, you might check the voltage on the no. 1 grid of the tube, at the volume control center pin, with black probe to the volume control ground pin (or signal ground). Set the voltmeter to 2000mv (2v) scale. As you increase the controls resistance (clockwise), see if you measure any DC voltage. If you are reading a little voltage, the tube is definitely the problem. Anytime a DC voltage appears on the volume control, one will hear a scratchy sound with rotating the control.Cheers.
So I have a tube amp (using 12at7) and I notice some scratchy noise as I turn the volume knob and so i switched to different tubes and the scratchy noise went away.
I thought he said in an above post that the scratchiness went away when different tubes were used.I see a little with different tubes mentioned later, but they could be bad as well. I apologize, though, if that is not the case.I still think it is a good idea to measure the grid voltage, just to be sure.Cheers.
