Tube Question from a newbie
0 Members and 1 Guest are viewing this topic. Read 5931 times.
Re: Tube Question from a newbie
« Reply #20 on: 27 Oct 2012, 11:07 pm »
Seems to me both problems can happen in this kind of circuit.
The amp owner will find the source of the prob.
medium jim
« Reply #21 on: 27 Oct 2012, 11:56 pm »
A bad preamp tube usually will let you know via a microphonic screech, distortion, lower output.  While it is possible the op has a couple of bad tubes, the chances are unlikely.  Unfortunately, scratchy/dirty pots are a reality and are an easy fix if you have access to them to spray some Caig De-oxit or other types of contact cleaner into them.  I prefer De-oxit as it is also a lubricant.
Jim
