Halide Design DAC HD vs. The Dragonfly
0 Members and 1 Guest are viewing this topic. Read 2785 times.
Mark Korda
    • Dawkus
« on: 20 Oct 2012, 03:58 pm »
Hi all,I'm about finally ready to try to get my computer connected to my hi-fi.I have read a couple reviews in Stereophile and Absolute Sound involving the Halide and the Dragonfly DAC's.I know the Dragonfly is less exspensive,but I would really like to hear your oppinions on which one any one of you would opt for....thanks a lot....Mark Korda
DaveC113
  • ZenWaveAudio.com
Re: Halide Design DAC HD vs. The Dragonfly
« Reply #1 on: 20 Oct 2012, 04:22 pm »
FWIW, I tried an older dragonfly and at the time my current DAC (Audio Alchemy XDP) was better. Now I have a Schiit Audio Bifrost and it was much better than the AA XDP. It is $450 with asynch. USB up to 24/192.
roscoeiii
« Reply #2 on: 20 Oct 2012, 04:45 pm »
How important is size and portability to you? A nice advantage of both, but you might be able to get better sound from a larger DAC...
adydula
« Reply #3 on: 20 Oct 2012, 06:48 pm »
Take a look at these....
Ones an USB Dac. the ODAC.
The other is an amp + ODAC.
http://www.jdslabs.com/storecat.php?fetchcat=5
Both really good....low cost and transparent.
Alex
