0 Members and 1 Guest are viewing this topic. Read 8587 times.
Hi, I am looking at making a discharge circuit for AC capacitance. I am going to be using a 50w resistor to bleed, but I don't want the bleed on while the device is in use. Thoughts?
Hi.Is it an AC circuit with an AC cap across the hot line & neutral line?Why need 50W such a huge wattage breeding resistor? What resistance would it be? Bleeding current should never be TOO large or it will only shorten the life of the cap.c-J
I just noticed the "AC" part. It's only capacitors in "DC" circuits that have a safety concern.
There is no transformer. Currently it takes 1-2 seconds for them to discharge across the relay.
100uf, 120v.
