0 Members and 1 Guest are viewing this topic. Read 8595 times.
My guess is this is part of his AC conditioner that was posted some time back and I suspect he's talking about ensuring there is no residual charge in the caps if someone pulls the plug while they are charged and then gets their fingers (or other body part) across the prongs. IMO if I'm correct, you need to have the resistor across the line at all times, you cannot count on a relay and it's circuitry always working. Food for thought..
My guess is this is ......
Sure... It is an AC conditioner. I just don't want to discuss it here, just discharging.
Yeah it is my own, per say. The initial concept behind using the amount of capacitance isn't from me, but I've been using it in practice for years now.
The benefits (and benign situation) of the 200uf from earth ground to neutral is hard to overstate.
PM sent.
(1) Our concerns should be directed at noise and interference currents that a pretty much below the radio range.(2)The Neutral wire's voltage drop will depend on the current draw and the total circuit resistance.(3) Your components, in the act of converting AC to DC add a lot of noise to the Hot/Neutral circuit. The last thing that you want to do is couple that noise to the Safety Ground which is connected to your components chassis's. (4) Noise currents to not go into your ground and then to Mother Earth and disappear! The noise currents use all handy routes to return to their sources.
Hi.(1) What lower frequency you are referring??
(2) If the house central grounding & grounding wiring are done effectively, the momentarily voltage drop from the chassis to the wall outlet ground wiring should be minimal. No sweats.
(3) If there is RFI noises potentials at the chassis, it should be drained away via the grounding wire. Noway such noise should stay on the chassis UNLESS the grounding is not done properly & effectively.
(4) That's why we should avoid multi-grounding loop so as to stop RFI coupled back to the chassis.
(1) Well below radio frequency. That's about 1MHz more or less.(2) It's not about the chassis to wall receptacle. It's about measuring the Neutral connection to the Safety Ground connection at your component. The more current your component draws the more it's voltage will drop. (Or rise referenced to ground)(3) RFI doesn't work that way. At radio frequencies, your speaker cables, interconnects and power wires (Hot, Neutral & Safety Ground) all can act as interference antennas.(4) Grounding sensitive components to Mother Earth can often increase RFI interference.(5) Ground Loops are about low frequency noise not radio frequency interference.
Again from Henry W. Ott's book:http://www.hottconsultants.coMore myths exist relating to the field of grounding than any other area of electrical engineering. The more common of these are as follows:4. To operate with low noise, a circuit or system must be connected to an earth ground. False, because airplanes, satellites, cars and battery powered laptop computers all operate fine without a ground connection. Henry W. Ott
Hi.What do these papers got to do with the low voltage & light light current consumption by our audio equipment???
(4) Our audio equipment are NOT portable & have to be powered by the RFI polluted powerlines. Our ears can detect intermoduation of RFI onto our music. Hense we have to install effective grounding devices to remove the powerline noises. Different ballgame with portable gear, my friend.c-J
