Raspberry Pi as music server
0 Members and 1 Guest are viewing this topic. Read 5320 times.
django11
  • Canuckistani
« on: 16 Oct 2012, 06:04 pm »
Just wondering.  Has anyone done anything with this?   http://www.mcmelectronics.com/product/83-14275
Kenjs
Raspberry Pi as music server Part II
« Reply #1 on: 3 Mar 2014, 02:25 am »
I have been kicking around the idea of using a RP or Audrino for a DAC or music server. More for a DAC, but cannot put togeather the concept of doing it or if it is even a benefit.
http://learn.adafruit.com has some pretty interesting things. One is a 12-BIT DAC with a Raspberry PI. I have also seen an Audrino used with Wolfson Audio DACS. Ch34eck this out http://hifiduino.blogspot.com/2009/05/arduino-controller-dac.html.
So it looks like it has picked up steam in new inventions with the PI and Audrino.
If anyone hasinterest or has done some of the projects I would like to hear from you.
chip
Re: Raspberry Pi as music server
« Reply #2 on: 3 Mar 2014, 03:41 pm »
I finally gave in and just got my RP last week. I haven't had tons of time with it. This is the one I got -
CanaKit Raspberry Pi (512 MB) Basic Kit (Raspberry Pi 512 MB + Premium Black Case + Micro USB Power Supply)
Here are some things I am going to try with it.
I have a HiFimeDIY Sabre U2 Asynchronous USB DAC that I will be using with it.
I am going to test out the following three pieces of software:
Runeaudio
Volumio
PiCorePlayer
and go from there.
chip
« Reply #3 on: 3 Mar 2014, 03:45 pm »
ramsubr
« Reply #4 on: 3 Mar 2014, 06:24 pm »
Runeaudio
Volumio
PiCorePlayer
and go from there.
I have tried Volumio and Picore player and I personally like the volumio better ( after some tweaks to enable it to run as a squeezebox player )
Volumio gives you the advantage of MPD+Airplay+squeezebox player all in one package. However, it is quirky at times ( note its a beta)
I use the M2tech Hiface II as a USB SPIDIF. The whole unit is powered by a battery pack to take it of the grid.
mcgsxr
« Reply #5 on: 3 Mar 2014, 07:27 pm »
I am sure it could work.
I am using a hacked Pogoplug as a music player with much success.  USB to HRT Music Streamer II, and controlled by iPeng on any iDevice.
I have heard that some folks have had success using one as the music server too, but I never got that to work.
I wonder if Daphile could run on a Pi?
dB Cooper
« Reply #6 on: 4 Mar 2014, 01:04 pm »
I want to know more about this and server based systems in general. What I eventually would like to have is a headless server controllable from an iDevice, with its content stored on some sort of solid state media (i.e., no moving parts.) This would feed a decent "Cheap & Cheerful" DAC. Right now the storage seems the biggest hurdle to doing it "C&C" as I have about 120GB of lossless music and am watching for SSD prices to fall.
chip
« Reply #7 on: 4 Mar 2014, 04:18 pm »
Some people use USB drives and hook them up to there system and play music back that way.
Some people use a NAS device - prebuilt or diy depending on ones needs.
I believe all these can be controlled in some way through an Idevice or android device.
JRace
  • Greetings one and Everyone!
« Reply #8 on: 4 Mar 2014, 06:54 pm »
My rasbbery pi just arrived yesterday.
I am using it with rasbmc at the moment.
SSD prices are still quite high, have you considered a network attached hard drive?
You will need the pi on the network to run it headless anyways.
Looks like the lower cost schiit dacs work with the pi.
