PLIIX or Neo:6 with DTS-HD & DD-TrueHD
0 Members and 1 Guest are viewing this topic. Read 3524 times.
jarcher
  • It Just Sounds Right
« on: 8 Oct 2012, 08:59 pm »
I'm running a 7.1 channel home theater system, but I notice that few titles, including DTS-HD & DD TrueHD Blu Rays, run past 5.1.
For that reason I've been using DTS-HD or DD TrueHD + Prologic IIX to artificially add the back two rear surround channels.
Does anyone have experience / opinions on whether for DTS-HD or DD TrueHD 5.1 sources whether it's best to:
A) Just run it natively as 5.1
B) Run it + Prologic IIX
C) Run it + Neo:6
D) Something else?
I like getting the use of all 7 channels, but wonder w/ 5.1 sources whether adding PLIIX or Neo:6 is better - or perhaps it's better not to
"artificially" add these at all.  Thanks!
Bob in St. Louis
Re: PLIIX or Neo:6 with DTS-HD & DD-TrueHD
« Reply #1 on: 11 Oct 2012, 12:57 pm »
Check out >>THIS<< site.
There are filters you can set that tell you what movies are available in what type of format.
Last I checked, there is an impressive list of 7.1 movies.
Bob
ted_b
« Reply #2 on: 11 Oct 2012, 02:06 pm »
I run PLIIx Cinema for all my 5.1 movies, and the results are great.  If my Denon sees 7.1 it does not apply it.
jarcher
« Reply #3 on: 11 Oct 2012, 08:53 pm »
Bob
I was going to recommend that site as well........Impressive piece of work & very handy being able to apply the filters.  340 titles in 7.1 channel sound.  Not a bad start, though pretty thin still compared to the overall releases.
jarcher
« Reply #4 on: 11 Oct 2012, 08:56 pm »
PLIIX w/ 5.1 has also been my default.  It does tend to blast too much the rear surrounds for the rear row audience, but it's probably assuming the sweet spot is the first row about 15 feet away (per audyssey).  Will have to work out some kind of pre-sets or something when there are or aren't people seated in the rear row.
jarcher
« Reply #5 on: 11 Oct 2012, 09:38 pm »
In case folks are still following this, I found the following thread on AVS forum, and in particular the explanations of Roger Dressler, one of the PLIIX creators, particularly helpful:
http://www.avsforum.com/t/1307055/dolby-pro-logic-iix-explained
Now I'm just wondering how / if Audyssey room correction is applied or dealt with under the DTS-HD / DD-TrueHD 5.1 + PLIIX scenario.
