0 Members and 1 Guest are viewing this topic. Read 48627 times.
Was a bit pressed for time earlier. This is just a prototype, because I'm impatient, the final solution will (probably) be a computer-based crossover to multi-channel DAC. Although maybe not, the computer-based crossover thing is great for digital files but not so much for analog sources... Regardless, for prototyping purposes the new revelation (for me anyway) is that you can make a $250 USB soundcard into an active crossover. I'm laughing about it, frankly, it's so obvious in one way and so out there in another. And it has analog inputs too, so who knows.
Pretty great isn't it? How are going to prototype a pair with only one set of real outputs on that thing? Planning on using the ch.3/4 1/8" outputs too?
I assume you must have researched the MiniDSP stuff? Perfect for prototyping and no computer required after set-up.
Sorry to derail, but who knows of any DIY speakers that have used the NEO 10? I hear it is mid-range Nirvahna, but want to read some reviews.
Has anyone determined shipping cost from AU?
No I don't think so. Can you define "sufficient volume"?
I said I was going to ask, but I'm still gathering questions for Rob. From auspost.com.au it looks like the postal service would want around 100, but Rob can give you a quote, maybe he has a better way (contact info on his site).
This thread is becoming more interesting to me. $100 isn't so bad for freight.
There's no law against owning multiple speakers that I'm aware of.
It would be wonderful if we could arrange a comparison between these and the Neo 8's or 10's. At least for those of us who are planning to use the Neo's as line source midranges .
See if I can fix that next week. /Erling
