OB for nearfield PC listening
0 Members and 1 Guest are viewing this topic. Read 4295 times.
this_is_vv
« on: 31 Aug 2012, 04:33 am »
after getting my first OB i cant go back in box speaker...today even went and audition a 2200$ pair near field speaker and  just walked out....i need to get my OB dose...
so as this is near field ball changes totally....again i am going active 2 way or 3 way not sure yet....i already have a tang band 4inch full range....
pair of 8 inch for low woofer
http://www.parts-express.com/pe/showdetl.cfm?partnumber=297-447
or
http://www.parts-express.com/pe/showdetl.cfm?partnumber=297-446
pair of tang band
http://www.tb-speaker.com/detail/1208_03/w4-655sh.htm
Crossed by minidsp and full range powered by a tube amp and woofer powered by ClassT amp
YJ TDA7492 Class D Amplifier 50W+50W stereo 4~8ohm speaker | eBay
any opinions any ideas??? i might add tweeter depending how i feel about the system...
any inputs...
this_is_vv
Re: OB for nearfield PC listening
« Reply #1 on: 23 Sep 2012, 02:11 am »
And here are the one i made it too........
sound is so far amazing....
a Seas with a Neo8
V
studiotech
« Reply #2 on: 23 Sep 2012, 03:03 am »
Oh, I like that one with the Neo8.  Are you running those with a sub?  Are you knocking down the top end rise of the Neo8?  I'd be inclined to keep working with these, add some woofers and wait on the new project.
this_is_vv
« Reply #3 on: 23 Sep 2012, 03:47 am »
No subs yet..may be down the line ....Running active crossover ...running seas from 45-2500 and running Neo8 from 1500-15k.....so far i havent done any measuresment of knocking top...
V
« Last Edit: 23 Sep 2012, 05:47 am by this_is_vv »
studiotech
« Reply #4 on: 23 Sep 2012, 03:45 pm »
You might want to get rid of the overlap btw the Seas and Neo8.  AND take measurements.  Design by ear never works out for the best.  Keep having fun!
Greg
this_is_vv
« Reply #5 on: 23 Sep 2012, 05:04 pm »
Greg
i am using active crossover so i can change it will just some clicks....wil do..right now enjoying the speakers...i have question can i implement a 6-8 inch woofer sideways with this...
like way they have implemented in V2 from Gr-research....i need to figure out how to bring lows to life
V
this_is_vv
« Reply #6 on: 28 Sep 2012, 11:56 pm »
Greg
Greg,
Yup it is sounding really BRIGHT and little HARSH need to tame it down somewhere.....i am thinking to get a Mic and a DEX 2496 behringer to control some frequencies....
this is my first time ig foray iinto DIY so i am still learning....need to know how to tackle down this harshness...
V
studiotech
« Reply #7 on: 29 Sep 2012, 02:43 am »
You should be able to perform the EQ with the MiniDSP, correct?  No need for an additional unit.  A mic and sound card or Omnimic from parts express.  Do you have an Iphone?  To get started, you can download an app for frequency measurements, just make sure it is one that takes the phones own mic response into account.  They work well enough to get an idea where the worst dips and peaks are.
Greg
this_is_vv
« Reply #8 on: 29 Sep 2012, 05:31 pm »
Greg
I am using dcx 2496... But that's for sure I phone idea... I do have one I phone an one android
studiotech
« Reply #9 on: 29 Sep 2012, 05:41 pm »
DCX2496 will work just fine as will an Android phone if you find a good app.  I used a DCX for years.  It is fine for your desktop use.
