H frames
0 Members and 1 Guest are viewing this topic. Read 4602 times.
Derockster
H frames
« on: 25 Aug 2012, 02:58 pm »
Hi All, can I use Eminence Alpha 15 in my H Frames?
Regards
Cleaton
SteveRB
Re: H frames
« Reply #1 on: 25 Aug 2012, 05:34 pm »
yes.
they will likely need their own amp.
Derockster
Re: H frames
« Reply #2 on: 25 Aug 2012, 06:40 pm »
Can you give me dimensions for the H frame?
Cleaton
scorpion
Re: H frames
« Reply #3 on: 25 Aug 2012, 08:59 pm »
Given this link: http://hi-fiworld.co.uk/index.php/loudspeakers/68-technology/138-open-baffle-loudspeaker-design-part-16.html I would recommend another speaker. Dimensions for a 15" I suppose could be 16 x 16 x 16 inches inner measure including or excluding baffle width. H-frames will be markedly less sensitive opposed to a flat baffle but in less need of EQ. What's the H complementing ?
/Erling
MJK
    • Quarter Wavelength Loudspeaker Design
Re: H frames
« Reply #4 on: 26 Aug 2012, 12:17 am »
Yes definitely. You can find the results of a trade-off study at the following link.
http://www.quarter-wave.com/OBs/U_and_H_Frames.pdf
Martin
Poultrygeist
Re: H frames
« Reply #5 on: 26 Aug 2012, 08:50 pm »
16 inches is cutting it very close. Going with 17 inches for the internal dimensions barely gives you an inch of clearance between the Alpha's edge and the sides.
Derockster
Re: H frames
« Reply #6 on: 31 Aug 2012, 03:42 am »
Hi everyone, thanks very much for your responses. Earling the H's will be complimenting my Acoustat panels. Would you recommend a flat baffle as opposed to H frames?
Regards
Cleaton
scorpion
Re: H frames
« Reply #7 on: 2 Sep 2012, 08:44 pm »
Cleaton, H-frames will be an excellent choice. Built the MJK-way and crossed 2nd order they will, as you learn on Martin's web, also be perfectly equalised for flat performance.
Just to choose crossover- frequency to mix with the other speaker. However  I would suggest that Beta15 might be better sonically than the Alpha15. The 1 watt sensitivity will be 86 dB for a Beta unit in the proposed H-frame and the bass wll go down to about 30 Hz no doubt.
/Erling
Derockster
Re: H frames
« Reply #8 on: 28 Sep 2012, 08:00 pm »
Hi guys just thought I'd share a picture of the system which the H frames will be used in.
