0 Members and 1 Guest are viewing this topic. Read 5233 times.
Dump the tube amp.Get a preamp and two or three decent identical solid state amps (100 watts per channel minimum) and a digital crossover.
I think the Super V is one of the best speakers out there...Maggies are great at sounding "big" and throwing a large soundstage, but are pretty poor with regard to dynamics, and are seriously lacking in bass impact. The Super V's will run just fine with your current tube amp, but the Maggies will certainly not.
OB's can have precise imaging if you use a narrow baffle and pull them at least 3 feet from a room boundary.Also, multiple bass sources is the only way to go if you are using BOX subs. With OB bass the side nulls effectively "remove" side wall reinforcement. They give you better bass because they interact with the room less.OB deep bass is definitely possible if you have enough woofers, with enough swept volume, and enough excursion. The Super V's meet all of those requirements, in spades.
