0 Members and 1 Guest are viewing this topic. Read 19306 times.
That looks like you have given the collar 1.5 turns rather then 0.5. If you have given it 1.5 then you need to remove one. That is nearly as bad as giving it 0.5 of a turn in the wrong direction (as per the manual).Steve
Plus..... I can't see much in the way of damping fluid in the pic. Not sure how the Versalex compares to the Amadeus in this regard, but it doesn't look like the ball is 1/3 submerged. As I've stated, if the Versalex is different as far as the fluid/ball relationship, never mind.
Do you have more skill to set the tonearm? Thank you very much!!
Looks like you both have the proper twist, and in the right direction. The left string should be over the right, which looks like you both have.The error I see is in wahaha's photo- get your counterweights together on the tonearm. Not proper. Otherwise could job. Make sure cartridge is perfectly projected on the shiny side of strobe disc. Rotate small wheel back and forth to line up sides of cartridge with reflection.
