0 Members and 1 Guest are viewing this topic. Read 7593 times.
FM tuners are a niche product now it seems... A good vintage one might cost a lot for what you get, will have uncertain life expectancy, and who knows what performance. Like turntables, there aren't many low cost/high quality tunas left.May seem like an odd suggestion but.. look at the Kloss Model One table radio, it has an excellent FM section and very good SQ (the built in speaker has EQ to make it "sound bigger" but this has no effect on the line out signal.) With a good antenna (critical for any tuna in low signal areas), it will pull in some really weak stations.wharfrat has a point; I listen to a lot of internet radio now too... Although my restored and modded Dyna FM3 beats it easily in SQ, I'll take music any way I can get it.
...there aren't many low cost/high quality tunas left.
doug sWill look for one of those antennacraft fm6's...as far as the tuner goes....for my use, the computer room system, its more important to be as sensitive as possible. The rack with the gear is right next to my keyboard so a remote is not needed, plus, I have at least a bazillion lp's to clean and listen to not to mention my 2-3 thousand cd's...so, sound quality takes a back seat to pulling in them distant tunes! I do have a tube buffer also that is not doing anything at the moment if the sony fdr x1hd turns out to be route to go..though, they are pricey and I really dont want to spend $200...thoughts??
i must take exception w/this statement. there's a plethora of excellent sounding and sensitive tuna awailable for ~$200 or less. sometimes a lot less.yes, even tho they may sound great and have good reception as-is, it is true they will likely sound even better if you send them out for refurb & alignment - we're talking 20-40 year old electronics, after all. and many were not properly aligned even right out of the factory. (even tho i got in a heated "discussion" w/someone on this site who insists if a tuna sounds good as-is, there's no reason to send it out for alignment/refurb; my ears and experience have told me otherwise.) spend more money on mods and they will rival the wery best. ymmv,doug s.
Wasn't referring to the vast used market or "rolling the dice" on a 20-40yo item as far as reliability and SQ. Referred to new market.
Ok, will find one of those fm6 antenna's and then I guess find a pole for it in the attic....
A box eh? I can do that My biggest problem is figuring out how to get the cable from the computer room to the attic..of course the computer room is on the lower floor so needs to run past the 2nd floor also...
Don't know why Sony stopped making the fdr x1hd. I had an order in for one for months and the company gave up and so did I as I've went through two CDP's (both got permanent "headaches" and stopped working). So I'm on my last CDP, when it dies I'm diving back into the music server waters for the main rig (still have an AV system with receiver and another music system with a receiver but they both use DVD's).
