Tuner buying advice needed...
0 Members and 1 Guest are viewing this topic. Read 7616 times.
hifigeezer
Re: Tuner buying advice needed...
« Reply #20 on: 31 Jul 2012, 09:52 pm »
doug s
its more important to be as sensitive as possible. I do have a tube buffer also that is not doing anything at the moment if the sony fdr x1hd turns out to be route to go..though, they are pricey and I really dont want to spend $200...thoughts??
I agree that an antenna is your best starting point.  For hard-core technical reviews and measurements of the Sony and Sangean HD tuners (and lots of other good FM stuff), look here:
http://ham-radio.com/k6sti/
Good luck and have fun!  If all else fails, buy a Squeezebox and listen on the web.
starkiller
« Reply #21 on: 2 Aug 2012, 07:28 pm »
Decided on the Sanyo T-35...will then figure how to get cables run to the attic and try out my old Radio Shack antenna and see whats what...
thanks for all the help!
doug s.
  • makin' music
« Reply #22 on: 3 Aug 2012, 03:35 am »
i have never tried this one; but those i trust who have, say it is wery nice, both in sound and sensitivity.  it certainly looks cool, w/its moving digital readout display!   :thumb:
http://www.youtube.com/watch?v=i7gu7_IGwes
doug s.
