0 Members and 1 Guest are viewing this topic. Read 6149 times.
It does work. It's not just repackaged slime. It's more like Silly Putty, but I had it specially formulated to make it flow right without being too slippery or gooey. It works like the nagaoka, but better. You can use the fast method or you can let it slowly flow across the record for deeper cleaning. I've also reduced the price by leaving out the mat. You can supply your own mat. And by the way its not that cheap to get it made to my specs. Warch for it again on Ebay or send me a message through this forum.
Just buy some Cyber Clean, the keyboard cleaning stuff, exactly the same product for way less. I haven't used it for records, I have a nice Nitty Gritty machine for that, but it works a treat for cleaning a stylus. I flatten out a quarter sized dab using the thin computer CD jewel cases then gently drop the needle in the goo, comes out perfectly clean. We tried sticky hands toys, which is the same chemical makeup, but the sticky hands material isn't as pure and has a little bit of calcium carbonate not fully dissolved that can get on the stylus. You can prolly get a 55 gallon drum of the stuff for $27.95 (or some ridiculously low price) if you look for it wholesale. The Zerodust product is the same as well, $69.95 for 1 ounce, jeez.
http://tinyurl.com/cqo9agwIt seems it would get into the groves, grab dust and not leave any residue. But to me it sure looks a lot like the kid's toy, SLIME. I think the guy is just repackaging SLIME and selling it for a huge profit.
Seems like a cleaver name for a jar of slime at $125. Non radioactive isotope, LOL.I suggest final inspection with an electron microscope. Check for molecular isotope residue, or green stuff in the grooves.
Seems Cyber Clean is the closest to the ability of the op discussion product. All are Wayyyyy cheaper than the original price of $125 for $15 worth of putty
Well, if it doesn't work you can always make funny noises with it.
