0 Members and 1 Guest are viewing this topic. Read 11762 times.
Well, I crossed the bridge today and picked them up. $700 and they are in fantastic shape. Babies 8/10 or better, black with oak strip.Cables - Will a higher gauge speaker wire provide better results? 14g, 12g, 10g?
Okay, I've had them in my system for a few days and I think I could comment on them as I am not new to Magnepan. There are a lot of differences between the MMG and the 1.6. I have to say that getting the 1.6s was a great move because it is basically the same speaker just much bigger. you get MORE of everything good about the MMGs. Image is larger, deeper and more "there." Bass is much more present. Imaging- with the MMGs imaging is amazing. Great recordings are so accurate, you are watching music. With the 1.6s, once I got them into the right position which for me is tweeters outside, slightly leaned back and toed in so they cross just behind me, the imaging exactly the same as the MMGs. However, with the 1.6s the sweet spot is much larger. With the MMGs I would sit in the spot and by moving my head a few inches, the soundstage would change. The 1.6s have more room than that. The center image is stable, large, deep and is the most believable of any I have had in my room. With the 1.6s there is more sound, it is bigger, it's a wall of sound. These speakers are huge and for my 12x16 room, they are probably at the limit of where I should go size wise. However, they sound great in this room. I use a Behringer DEQ2496 for EQ. The way my system is set up, I can easily switch between an purely analog signal and a digitally altered signal (via the Behringer). The 1.6s do amazingly well with digital eq. Even the slightest image adjustments are noticeable. I guess the word is transparent...
