Anyone compare MMK(Evox Rifa) cap with BG "NX" cap
0 Members and 1 Guest are viewing this topic. Read 2005 times.
SamL
« on: 30 May 2004, 10:14 pm »
I know a lot of people recommend RTX over MMK but the price is not an encouragement. Just wonder if Black Gate "NX" cap a worthwhile upgrade from MMK cap?
Appriciate you comment.
Sam
ginger
Blackgate NX
« Reply #1 on: 3 Jun 2004, 05:15 am »
Saml,
I have experimented widely with Blackgate caps including the NX. The NXs are seriously lovely providing there is not too much DC bias on them. I am using 22uF/6.3V NXs for the Vbe bypass cap (C7 I think) and the AC ground cap at the bottom of the feedback network (C2 I think). It should also work well for the input cap (C1) but could suffer "colateral damage" if you ever have a fault in your preamp (because of its low voltage rating).
Ginger
MarinRider
« Reply #2 on: 7 Jun 2004, 06:18 pm »
If you are really confident (and I mean really, really) you will never get dc on the output or your pre, get rid of C1 altogether.
My pre has a Sonicap on the output, which is way better than the MMK. So it's pointless having another cap on the AKSA input.
SamL
« Reply #3 on: 9 Jun 2004, 05:27 am »
Hi MarinRider,
Don't think I'll removed C1 as I plan to fiddle the opamp in my player and they'll go through a passive valume control and to my aksa.
The Sonicap that you mention. Is that the one from Jeff off Soniccraft? Was told that they are very good.
Sam
