0 Members and 1 Guest are viewing this topic. Read 4420 times.
Connect your Roku digital output (labelled coax or digital, or maybe even toslink optical) to the DAC with digital coax or toslink optical cable. Coaxial SPDIF digital connection is usually superior sound quality than optical.
Do all the DAC act as preamplifiers also? Will the videos's audio improve with the DAc? So am I to understand that it doesnt matter whether the DAC has a remote ? I am assuming the amp does
The Cayin A100-T is a very nice tube integrated amplifier. It has 4 analog inputs, one of which is a "Pre-In" input. This is also sometimes referred to an HT Bypass input. The Pre-In input bypasses the volume control and is used to connect a stereo preamplifier or an HT receiver's Front L/R channels, either of which would control the volume for that input, essentially using the amp as a power amp. In other words, that input is "full volume" and cannot be used to connect an ordinary analog line source.So that leaves 3 inputs, one of which would be used to connect the output of your DAC (which would have several digital sources connected to it). After connecting the DAC, you would now have 2 analog inputs remaining. You would only need a DAC that has an analog input if you have more than 2 other analog sources and need to acommodate a third.Steve
So,would the Mytek DAC I mentioned work for me?
The Mytek is a little more sophisticated than many DACs as evidenced by a FireWire input, two USB inputs, Word Clock In/Out and DSD capability. However, it only has one optical Toslink input and one coaxial input. Devices like disc players usually have both coax and optical, but many consumer devices like your Roku, Apple TV, WD TV Live, cable boxes, DVRs, TVs, etc. may only have an optical output. So you will have to determine if it has the number and type of inputs you will need.If you search AudioCircle for Mytek you can find some posts about this DAC. There are also several topics about it on www.computeraudiophile.com.Steve
