Audio/Video Gear and Systems
The Apple Core
Crimson
FLAC Conversion Software for Mac
0 Members and 1 Guest are viewing this topic. Read 2732 times.
kbuzz3
4 Jul 2012, 06:57 pm »
Ive not had great experiences with MAX. Can anyone recommend a similar easy to use software. I can't tell from the dbpoweramp site whether it works for mac but appreciate any suggestions
frogboy2727
Newbie
Re: FLAC Conversion Software for Mac
4 Jul 2012, 07:09 pm »
I've been using XLD, for quite awhile. Excellent free program.
Al ..
saeyedoc
Reply #2 on:
4 Jul 2012, 07:53 pm »
Try XLD
kc8apf
Are you sure what side of the glass you're on?
Reply #3 on:
4 Jul 2012, 08:14 pm »
Another vote for XLD. Best ripper/converter I've used on a Mac.
dB Cooper
Reply #4 on:
5 Jul 2012, 12:48 am »
MAX was once good but appears to be abandonware at this point. Another vote for XLD here, and MediaHuman Audio Converter isn't bad, although more of a work-in-progress. Converts to/from a variety of formats but no ripping functions iirc.
guf
Reply #5 on:
5 Jul 2012, 02:46 am »
I stopped using flacs for a few years and revisited about 6 months ago. xld made the whole process fun. Its so fast with modern processsors. I think i read it utilizes all cores of your processors. takes seconds compared to minutes from years ago. great software!
abernardi
Reply #6 on:
5 Jul 2012, 04:37 am »
What problems have you had with Max? It's been working great for me for years, as does the other sbooth programs
simon wagstaff
Reply #7 on:
5 Jul 2012, 12:44 pm »
I have used xact for years. Since I started to use decibel for playback I have no need to decode anything.
kbuzz3
Reply #8 on:
5 Jul 2012, 01:18 pm »
Thanks everyone for the suggestions . Re max, my issues are it has problems searching and finding tracks, it won't find artwork, and most importantly simply won't convert a lot of tracks, getting to 98 percent then errors.
dB Cooper
Reply #9 on:
6 Jul 2012, 02:23 am »
abernardi, max does nothing for me- meaning it crashes whenever I try to rip anything. Used to work fine. Who knows, ymmv...
WheelerMK
Reply #10 on:
8 Jul 2012, 12:36 pm »
I started to use MAX to transcode files and it was fine. XLD seems more robust when it comes to ripping and I do like the reports and AccurateRip
kbuzz3
Reply #11 on:
8 Jul 2012, 02:04 pm »
Thanks everyone xld so far s much fasrer and more stable then max. Ill have to experiment further...
dB Cooper
Reply #12 on:
8 Jul 2012, 09:46 pm »
I think MAX just doesn't like me.
The Apple Core
Crimson
