0 Members and 1 Guest are viewing this topic. Read 9758 times.
or get this one here on AC ,u can't go wrong with this cartridge http://www.audiocircle.com/index.php?topic=107309.0lapsan
The Yamaha MC-1 was a very good cartridge from the good old days (1979).There were two versions available:Yamaha MC-1X: SME compatible headshellYamaha MC-1S: half inchCompliance: 18 x 10-6 cm/dyneOutput Voltage: 0,37 mV / 1 kHz, 100 Ohm
I'd think that a worn needle might be of greater concern.
Armature Air core coil plate laminated aluminum thin film (layer 2)Cantilever High-purity beryllium, tapered pipeThat's extraordinary, a rare beast indeed, as rare as a Klingon kangaroo. If not enough gain I'd sell the 640 or put it on another system. Good luck.
At some points I believe in the measurements !So when the well-damped resonance frequency peak with an SME 3009/IIis at 7 Hz, don't tell me the dynamic compliance is 11 x 10-6 cm/dyne.I guess that's the 100 Hz value.There was a third cart in the same line: The JVC MC-1.I guess all three carts are OEM.A review of all three carts is in TAS 17.
Toni,I can't read the brochure or article you posted. Is there any other vital info?
