Help with mc cartridge / Cambridge 640p
0 Members and 1 Guest are viewing this topic. Read 9759 times.
Nick77
Re: Help with mc cartridge / Cambridge 640p
« Reply #20 on: 13 Jul 2012, 11:14 pm »
Just wanted to report back, the cart sounds excellent and i am able to use the 640p. It has been modded with all new caps and op amps. I do have a gain issue though, have to run my buffer at 75-80% for approx 80db. I have ordered some resistors that i can add to the 640p to boost the gain by 6db. That should do the trick but it is quite listenable now.
Thanks for all the input.
