0 Members and 1 Guest are viewing this topic. Read 6618 times.
What's the "Y" scaling at?
It looks like 10 dB. Look all the way to the right of graph he posted.Best,Anand.
It looks like 10 dB scale. Look all the way to the right of graph he posted.I agree, there seems to be no sub. Is there a way you can post your graph with more detail in the X axis, i.e. spread it apart a bit more so it's not so jumbled up?Where is your microphone? Are you playing both speakers at the same time, or only one at a time during these measurements?Thanks,Anand.
calibrated in what manner?
I have used the AudioTools app on the iPad and they do state there are issues with low end response using the internal mic. The only issue I have had with the App is from 65Hz down, the response is always rising quickly. I have not contacted the company yet about this issue.The rest of the FFT meausres/looks very close to other programs I have used with external mic's (berringer, RS, etc.)
Just that what's on the graph is fairly close to reality. It probably isn't, audiotools say "We have compensated for these mics as much as possible, but given the physics of the situation, the usefulness of the low frequency information is limited."It's something to be aware of.
I don't have access (or desire in particular) to all the regular acoustic tools (REW, sound card, laptop, mike, boom, etc).
Thanks guys--Rives has not measured this room, as that costs an extra 1.5k thereabouts. To be honest, I wasn't really focused on the bass---more on that 100hz and up response and what improvements could be had. It seems like my treble really looks to falls off quite a bit, although it doesn't seem particularly warm in room. There is no issue with treble and these mikes from everything i've read.I can also try my iPhone as well I guess- maybe that is the difference between the bass. Will do that this evening. I don't have access (or desire in particular) to all the regular acoustic tools (REW, sound card, laptop, mike, boom, etc).
