Room FFT
0 Members and 1 Guest are viewing this topic. Read 6612 times.
DTB300
Re: Room FFT
« Reply #20 on: 21 Jun 2012, 05:02 pm »
Audiotools is calibrated to use internal mikes for ipads/pods.
Rising bass below 65Hz was confirmed as an "issue/problem" with the internal mic with Studio Six Digital.  They stated when IOS6 comes out, it should help address this issue.
Re: Room FFT
« Reply #21 on: 21 Jun 2012, 05:22 pm »
I have read the 3GS had the best mic for audiotools.  The mic in the 4 was even more optimized for the voice range and not as accurate with audiotools.  When I get comfy with REW I will be comparing it to audiotools FFT app.  Nice to hear ios6 may help the situation.
KeithR
Re: Room FFT
« Reply #22 on: 22 Jun 2012, 02:35 pm »
ok, folks- Here is the iPhone and iPad 2 graphs, respectively.  Not much difference:
DTB300
Re: Room FFT
« Reply #23 on: 22 Jun 2012, 03:05 pm »
ok, folks- Here is the iPod and iPad graphs, respectively.
Which iPad version - 1, 2, 3?  Here is my initial graph.   The 250Hz NULL is a room mode.  As you can see I get a RISE from around 80 on down.  Other than the 250 Null, I am happy with the response and of course the sound.
Soon I will attempt to address the 250 Null with some room placement.  Trouble is I have VERY little room to move things around (speakers, seat, etc.).  Might be time to talk to Bryan and Glenn about the possibility of a Scopus Tuned Trap.  (Working with Bryan now....will post update later)
« Last Edit: 22 Jun 2012, 04:47 pm by DTB300 »
*Scotty*
Re: Room FFT
« Reply #24 on: 22 Jun 2012, 06:27 pm »
KeithR and DBT300, StudioSix recommends that test signals should above 70dB to maximize the signal to noise ratio with an iPod/iPhone etc..
 DBT 300 the suckout you are measuring at 250Hz is most likely induced by floor bounce cancellation and will not yield to changing the speaker's location.
Scotty
*Scotty*
Re: Room FFT
« Reply #25 on: 22 Jun 2012, 07:11 pm »
Deleted, stupid iPhone.
DTB300
Re: Room FFT
« Reply #26 on: 22 Jun 2012, 08:28 pm »
It is more room length/width modes along with seating position.  Height changes do not affect this null.
I will try a higher test signal to see if things change
