Is the Transcendence 7 still a worthy pre
0 Members and 1 Guest are viewing this topic. Read 1441 times.
guf
« on: 18 Jun 2012, 04:33 pm »
If it could be had for a good used price? sure there new ava stuff is better but the reviews from 10 years ago were great.
Charles Calkins
Re: Is the Transcendence 7 still a worthy pre
« Reply #1 on: 18 Jun 2012, 04:38 pm »
I had a T7 ECR preamp. Very good pre but not as good as the Avastar.
 If you can get one on the cheap I'm sure Frank can upgrade it for you.
                                                 Cheers
                                               Charlie
pstrisik
  • Holding pattern in Audio Nirvana in the PNW!
« Reply #2 on: 18 Jun 2012, 06:02 pm »
There is a Transcendence 8 on ebay for $900 right now.  Phono stage and remote.
edit:  oops - just checked it and someone snapped it up.
........Peter
avahifi
    • http://www.avahifi.com
« Reply #3 on: 18 Jun 2012, 06:38 pm »
The Transcendence 7 hybrid preamp remains a darn nice unit.  Depending upon the physical layout of the PC cards, it might be possible to upgade it with the most recent Exicon mos-fets and perhaps even newer tube types.  I would have to see sharp photos of the audio boards to determine this for sure and give a firm cost estimate.
Frank Van Alstine
