0 Members and 1 Guest are viewing this topic. Read 8030 times.
I'm a firm believer that each piece of music has an "optimum" volume level necessary to sound it's best. Yes, it can still sound good lower, and sometimes higher, but usually there's one level where it just gells.That being said, to achieve that optimum level you have to consider:- the efficiency of the speakers- the volume level of the recording itself (and we all know that can differ dramatically)- the dynamic of the presentation as well (peak to trough)As such, I believe that I need sufficient gain to give me options to make those low volume recordings come to life on my highely inefficient speakers (83db). I therefore need power in my rig. Someone with 106db efficient Klipshorns can get away with 3 watt SET amps and probably have even more dramatic dynamic swings than I can achieve with my 1000 watt amp. I guess there are just many different ways to skin the beast.
Have you seen this article?http://www.diyaudio.com/forums/diyaudio-com-articles/186018-what-gain-structure.htmlI am a firm believer that modern components have too much gain. You do not need a pre with 14db and a power amp with 32db. Ymmv.
How is speaker sensitivity factored into "total system gain"? Do you add it, or add the difference relative to some other reference like say 90 dB/W/m2?Serous question, for the Lab.
I don't have a "system gain philosophy"? The gain a component has, if properly engineered, should have no bearing on how well it performs or sounds. In my system I have a roughly 3600cu.ft. space to fill. My preamp has zero gain, the power amp has 26dB gain with 1volt in sensitivity and my speakers have about 96dB sensitivity. The problem I have had with preamps with more than 7dB of gain has been related to the ability to use the volume control to achieve a desirable SPL in my room. A preamp with 14dB gain cannot be used because it is either too loud or turned all of way the down. There is no usable area of the potentiometer's travel. Obviously this is the worst case scenario, if the speakers had 89 to 90dB sensitivity the problem would be solved. This only kind of problem with gain that I have had to deal with. Depending on the loudspeaker's design I can see all sorts of thermal compression problems cropping up with speakers rated at 83dB and using conventional cone based drivers. I confess that I don't understand werd's preference for staying under 40dB gain for his system. Scotty
I am still wrapping my head around this stuff. It seems to me that the power amp is where the attention needs to be paid. You want to be able to drive it to maximum power. So you look at the source output and then you should know how much gain is needed. I could be wrong.
Actually, db per watt provides a measure of how much power one gets out of the amp. Voltage gain in and of itself does not provide the same level of detail. Kind of need to know both.
