0 Members and 1 Guest are viewing this topic. Read 8029 times.
Davey is correct. In my case about 1volt peak output from my USB DAC in a system with 26dB gain and 96dB speakers can be insufficient. I have a few CDs ripped to wave that could another use another 6dB of gain even when I have my volume pot at maximum. Rather than look for another preamp, I will probably have a friend re-record the CDs with 6dB more gain. Scotty
Vortrex,You might notice a system gain "problem" by the position of your preamp volume control. Is it below 12 o'clock all the time and sometimes below 9 o'clock? That's an indication you have too much gain in your system.Of course, when you bring vinyl into the picture it can become even more complicated. I've noticed many contemporary preamps don't have enough gain in the phono section and too much gain in the line-amp section. The Audible Illusions preamps are like this. Not very well suited for line level source components.....and also horrible useability because of separate L/R volume controls......but that's a another subject. Cheers,Dave.
If you don't have a signal to noise issue then you have no gain issue. If you can crank it as loud as you want, you have no gain issue.
I am a firm believer that modern components have too much gain. You do not need a pre with 14db and a power amp with 32db.
if I have 2.4mv cart to 44db phone pre to an amp with 25db gain to 88db speakers, am I missing out on anything?
I do not concur that db per watt is a useless spec. It’s (just) a spec (like many others), and can provide some insight into performance. I would concur that some specs are more useful than others. Why, for example, do you think Papa Pass made the F4? It provides zero db gain, but puts out 25 wpc in stereo or 100 watts in mono. Just the ticket for someone who loves the sound of a flea powered amp, but needs watts to drive the speakers.
