0 Members and 1 Guest are viewing this topic. Read 48205 times.
Why do only I see these things? Am I the only bore here ...
I though this Alpair freq chart similar to the Nirvana Super12CF, it looks both use the same kind of paper for the cone.
If it helps any the A12P transfer function is raw without smoothing. My pair are undergoing the break in process driven by a 18watt Scott222 tube amp. I'm listening at ~2' above as if they were headphones. I'm not hearing vocal sibilance, shout, or other nasties...yet, fingers crossed they continue to please when in a proper cabinet.
Chrisby:I noted that both drivers up and fall +- together, on the freq chart, of course the amplitude is not the same.DRIGUY:Thanks for your detailed report, MarkAudio always made great products.Would I ask what woofer are you using on the OB??What frequency are you cuting??Thanks
Am hoping to hear the Alpair 12's this summer (Chris/Dave?)
I set the sub at about 90 which when summed gets you pretty close to 100Hz. I use GR Research open baffle servo control subs. My amps are Emission Labs 300b XLS based with custom wound Electra-Print OPT's. Source is a 16 chip TDA1543 DAC with a 6922 output stage (not a buffer) with built in volume control.
Planet10:I post the old freq chart from the Super12CF, which allow some comparison with Alpair12.After some time David post a new datasheet from the Super12CF on the CommonSense site, that is this chart you post.The driver is the same, but due changes in room temperature/humidity some TS and the graphic have changed.
.... unless with notch correction circuit, what is a heresy for a fullrange driver.
Why?Bob
FR, I'm a single driver fan too and consider crossovers evil, but what is the goal? If it's good sound with a single driver, why not use some "help"? Isn't the cabinet a filter of sorts? If I use EQ instead of a baffle step is that a "no-no" too? If I listen in a room, isn't that altering the sound?I love the purity of single driver, but face it, there are circuits throughout the audio chain.
This fullrange seems absent from this peaky in the 1k - 3K range.http://www.audiocircle.com/index.php?topic=108486.0
Um, that looks to me like about 10 dB rise at 3 kHz.
