0 Members and 1 Guest are viewing this topic. Read 22226 times.
Well, i got a question regarding difraction from cabinet edges.If im not mistakne, the edges of the cabinets are usually rounded over to control difraction. My question is, wouldnt a beveled edges have better control since the egdes are straight?
Here is how I treated the tweeters on my speakers using 9mm thick size 15 double wide felt insoles.The speaker disappears better and the highs and midrange are smoother and seamlessly integrated.Scotty
Where do you obtain those felt pads? I was going to make some from snow shoe liners but I went with the little stick on jobs instead.
And you'll get 50 answers on speaker edges anyway with 9 out of 10 not based in reality of any kind.
( I have grills that cover all this....LOL)
If the cabinet is slimmer, the round or beveled edge have less effect on diffraction, is that right?I also noticed, for example a speaker with 5 inch driver , the overall driver will usually sit on the baffle that is under the interior width of the cabinet. What happens if the frame of the driver actually sit over slightlly over the interior width of the cabinet? That way a slimmer cabinet can be built, but i dont see people doing it, what kind of compromise can that have?
