0 Members and 1 Guest are viewing this topic. Read 22225 times.
The concept is to avoid any sharp edges. In theory a sphere (like the Gallo balls) would be ideal (except for internal resonances). A couple of egg shaped speakers have been developed for 2-way designs, but are expensive to set up for manufacturing.
If the cabinet is slimmer, the round or beveled edge have less effect on diffraction, is that right?I also noticed, for example a speaker with 5 inch driver , the overall driver will usually sit on the baffle that is under the interior width of the cabinet. What happens if the frame of the driver actually sit over slightlly over the interior width of the cabinet? That way a slimmer cabinet can be built, but i dont see people doing it, what kind of compromise can that have?
This won't help anybody but here I go from what I gather from this is you can 10 different people and get no answers that help. I've heard round are better ,,, square corners better . Does anybody REALLY think there are definitive answers on this.
Is defraction more noticeable in near field or the same for far? From the pictures I've seen it seems like the sound from edges doesn't seem to travel very much distance (or is this just my non knowledgeable way of looking at it).
