New (NooB) SP2 Setup Help - No LCD
0 Members and 1 Guest are viewing this topic. Read 2618 times.
kayemee
« on: 12 Jun 2012, 09:01 am »
Hi
I have just received my sp2 and 875HT.
I have unboxed and went to run the setup but the LCD is blank. I pressed the OSD button on the remote, rebooted the unit a couple of times but I can't get anything to show on the LCD.
Any advice or help would be much appreciated
Cheers
Kurt
  • The Demo is Everything!
    • http://www.bryston.com
Re: New (NooB) SP2 Setup Help - No LCD
« Reply #1 on: 12 Jun 2012, 11:09 am »
Hi
Cheers
Kurt
Hi Kurt,
Sounds like the LCD is not set correctly or it is burned out.  Where did you purchase it?
james
kayemee
« Reply #2 on: 12 Jun 2012, 11:19 am »
Hi James - thanks for your quick reply.
I purchased it through Syntec in Sydney, Australia
They are closed right now (it's 9.17PM).....my excitement got the better of me and I decided to hit the forum for possible answers.
The unit seems to switch sources and adjust volume from the remote just fine - it's just the LCD that is black and not lit up
Cheers
Kurt
« Reply #3 on: 12 Jun 2012, 12:45 pm »
Cheers
Kurt
OK it may just need a brightness adjustment or a new LCD.
james
kayemee
« Reply #4 on: 12 Jun 2012, 12:48 pm »
Can brightness be adjusted by the user or is a return to dealer adjustment?
« Reply #5 on: 12 Jun 2012, 02:10 pm »
it is internal so a qualified dealer or tech.
james
kayemee
« Reply #6 on: 12 Jun 2012, 02:15 pm »
Thanks for the advice James _ I'll touch base with them tomorrow
Cheers
Kurt
alexone
« Reply #7 on: 12 Jun 2012, 05:49 pm »
hi, Kurt!
how do you like the 875? is the amp new or used and how many speakers do you have connected to it?
thanks,
al.
alexone
« Reply #8 on: 12 Jun 2012, 06:05 pm »
James,
the 875HT is not SST2 yet, right?!? will it be updated soon?
thanks,
al.
kayemee
« Reply #9 on: 12 Jun 2012, 09:53 pm »
Hi Al
The 875 rocks! I hooked it up to a Marantz receiver I have, the additional sounds while watching TV/movies was remarkable. All of the different sound modes work properly (they didn't when the Marantz was amplifying) - very excited to get it all going!!
The amp is brand new and I hook it up to 5.1 speakers...unfortunately they are Bose speakers....but hey...I can always upgrade....
Cheers
Kurt
kayemee
« Reply #10 on: 13 Jun 2012, 04:22 am »
James
I got in contact with a local service repair agent - they will have the unit tonight and will work their magic on it
Many thanks for your help - the great service from Bryston that people talk about on this forum has continued
Cheers
Kurt
alexone
« Reply #11 on: 13 Jun 2012, 05:46 am »
hi, Kurt!
thanks for reply. i have the same setup at home in the bedroom (SP2&875) and the sound is really cool!
one more question: since your amp is brandnew does the power button, frontplate or the ratings label at the back of the 875 indicates it as a "SST2" amp?
many thanks,
al.
kayemee
« Reply #12 on: 14 Jun 2012, 01:00 am »
G'day Al
the unit I purchased was not the new model so it doesn't have the features you have listed.
BTW - that is one hell of a rig for a bedroom!
Cheers
Kurt
alexone
« Reply #13 on: 14 Jun 2012, 05:27 am »
ok...thanks, Kurt! yes, this setup is a mighty one :green: even if the channels are not bridged it has really good power!! i like the fact to have 8 channels of Bryston power :thumb:
al.
