0 Members and 1 Guest are viewing this topic. Read 7197 times.
If one was wanting to do a computer setup with room correction and 8 analog outputs what is necessary?
I have a Hypex DLCP up and running in my system. It's a pretty neat unit with some advantages and disadvantages compared with the DCX2496 and miniDSP. Only six outputs though. Cheers,Dave.
You may even want to look into doing it all in-computer. My system is like that now. In theory I can run analog through it although haven't actually tried it yet. I'm not sure what the software is on Windows but randytsuch was looking into, there's a thread further down the page.
I am currently running a actively crossed and biamped system. I am using a MiniDSP and am wondering if I can do better. I think I like the idea of the DEQX acting as the DAC. That way I will limit the redundant conversions. I am also not digging the 0.9v output of the Mini. Maybe I need to switch to a balanced Mini?If one was wanting to do a computer setup with room correction and 8 analog outputs what is necessary? What are the main parts? Can my vinyl be corrected also? Will $1500 get me there?I am very happy with the sound of my current setup. Just looking to explore options.
The nice thing about using a good conputer audio interface vs a speaker management box like DCX, is having excellent quality analog (mic) inputs. the DCX analog inputs are a total joke.
I run DCX2496 in my Sanders setup. Just for kicks, I measured its performance using its analog inputs. My SA showed THD of 0.00069% with all harmonics so far down (-120dB) they are in the noise floor. Objectively, this is spectacular performance.
I have tried the Mini DSP as well as the new version of the DEQX. Both are good units with strong and weak points. The DEQX has the best built in measurement software etc. however IMHO lacks on the DAC side of things. Now I know some will disagree and that's ok, it does enough stuff very well to accept the DAC limitations.You might want to give Clayton Shaw a call he has been at this for a while now and has a very good working experience of this gear. He has chosen the Prism gear, great DAC's and Preamp. Of course then you need to add the software for room correction etc. Metric Halo goes a great job as well, I thing you can get everything you want without breaking the bank.
