0 Members and 1 Guest are viewing this topic. Read 38908 times.
Russell, I would be wary of extrapolating a rule of thumb for telephone bandwidth to hifi. With regard to the question "when do you need to go below 40 hz?" it needs to be remembered that no speaker stops producing output abruptly at 40 Hz (or any other frequency). And the curves vary by speaker - a sealed speaker with a -3dB point of 40 Hz will produce more output at 20 Hz than a ported speaker with a -3dB point of 40 Hz, as an obvious example. There's also potential drawback of pushing your in-room response as low as you can, while often 20 Hz is stated to be necessary for true hi-fi, you run the risk of getting very poor decay times at such low frequencies. I found an in-room -3dB of 30 Hz (in my room, my system, etc) preferable to 15 Hz.[Edit: added a very important "at 20 Hz" qualifier...]
Lowest fundamental on a bass guitar tuned to A440 is about 43Hz IIRC.
.Obviously organ music goes much lower. Characteristics of the room and speaker placement come into play as well. No shortage of variables.
But the question is how often are the lowest note or two on this or other low-reaching instruments actually played? Probably not enough to make it any kind of system need or requirement.
Who said LP can't deliver sub subsonic notes??c-J
Nobody. Just watch the woofer move when a warped record is on the platter.
I would recco dual subs and if ya can try a third one behind you.
